| Chip Amps Amplifiers based on integrated circuits |
I am planning on building some bookshelf speakers for my desk for use with my computer.
maybe ZBM4.. maybe ZMV5.. or dayton budget.. dayton II, IDK I haven't decided. The point is that I need an amp that will be on most of the time and not waste too much power, but still be able to effictively drive these speakers without too much compromise Thoughts appreciated Thanks, nullstring EDIT: perhaps I posted this in the wrong forum? I was orginally planning on building a gainclone, but it seems like these would be too inefficient and overkill for my purposes, but I assumed I would still want a chipamp. Let me know if thats not the case. Last edited by nullstring; 25th January 2011 at 05:39 PM. |
#2 |
I see now that I should most certainly be in the Class D forum...
#3 | |
Or maybe not..
So, what exactly do I want.. |
#4 |
Hi Nullstring
It all really depends on the listening level you want from you speakers. If they are sitting on your computer desk they will be very close to you so not as much power needed . also the size of the room will be another part of the equation. smaller speakers with high sensitivity tend to be weaker on bass response. Mad Mark |
#5 |
The room isn't huge. It's 12 x 14 (ft), but it is a bedroom, so I won't always be right next to the computer.
I'm not really a basshead, and I don't really need the speakers to be excessively loud. I have more of a quality over quantity mindset. Last edited by nullstring; 25th January 2011 at 11:19 PM. |
#6 |
I thinkg that for you purpose i can recommend the hifimediy T2 amp based on TK 2050 Tripath chip. In my opinion it is ideal allrounder, giving reasonable power suitable for even not highly sensitive speakers. It is very well built and the price is very friendly.
Hifimediy|Hifimediy T2 2*100W@4ohm amplifier |
#7 |
A half decently made lm3886 would also do this job and gives very good sound quality.
#8 |
Both seem like they shouldn't be left on 24/7.
Perhaps I should get over that fact and deal with flicking a switch. However, it seems like a gainclone will be better in the long run. I wish there was a spoon-feeding tutorial website for this thing like there is for most other projects I do. Not that I need to be spoon-fed, but the.. lack of organization of information for this project is intimidating. |
#9 |
No amplifier should be left on 24/7.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#10 |
You don't need to leave the actual amplifier on all the time.
Use a circuit (always on, powered maybe by a small wall wart) that switches on a mains power relay once a music signal at the input is detected. Arrange so that the amplifier stays on maybe for a minute (or more) after detecting the most recent music signal at the input, so that it doesn't switch off annoyingly between songs (555 timer maybe?). |
| Bookshelf speakers | unknownuser200 | Multi-Way | 20 | 21st January 2012 06:09 PM |
| Sugestions for bookshelf speakers to build with my new tube amp | Guytute | Multi-Way | 5 | 30th December 2008 06:55 PM |
| bookshelf speakers | Mike Gergen | Multi-Way | 6 | 30th April 2007 12:19 PM |
| bookshelf speakers - need help | ziv_r | Multi-Way | 1 | 24th April 2006 11:20 AM |
| Bookshelf Speakers | avguy | Multi-Way | 32 | 10th November 2003 10:36 AM |
| Page generated in 0.11797 seconds (71.82% PHP - 28.18% MySQL) with 10 queries |
