Old 26th July 2003, 01:26 AM   #41
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: Engineering post
Originally posted by Fred Dieckmann
"You probably have to ask Fred, to post some engineering illustrations"
Someone might even ask why you are using the type of Caddocks that are no where near the good Caddocks.......
I will leave it to you to research as you desire.
BTW I don't know what solder you use but lead free silver solder joints don't look as nice as regular solder. They but sound better. There are ways to do composite solder joints for sonics and looks and good wetting. More R and D. as I know you don't want to discuss proprietary stuff on the forum.
First answer is simple, this is the only type my supplier stocks. I tried it almost by accident, ot works fine, isn't too expensive, so I don't feel like looking for anything better. I tried $27 a pc. Vishay S102 in this location and it was no match. I actually did my R&D here: http://www.diyaudio.com/forums/showt...874#post18874. One reason I didn't even consider TF020 is too big lead spacing and overall size.
Having such nice experience withthose Caddocks in a feedback loop, I thought they will be also great as I/V resistors in TDA1543 circuit. But, no, the Rikens are much better here, more neutral and transparent. I still didn't find a single location where Vishays S102 sound good. To me, they are too soft and laid back. Actually I'm using them in swithing volume control in my monoblocks and they seem fine there. It may be true that they are most neutral, but I prefer more "spice" to my music.
Second, I'm using Cardas solder. I had a hard choice between few other brands, but somebody suggested: if you are using Cardas binding posts and Cardas wire, why not go with Cardas solder? You see?
I also tried silver solder and didn't like it.
BTW, I like your other post much better
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th July 2003, 03:04 AM   #42
Originally posted by Elkaid
hehhehehe
what's this ?
A good excuse
www.audiosector.com
Old 26th July 2003, 09:43 AM   #43
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Please read this to understand about acoustic feedback.
Russ Andrews - Firm Foundations
I cannot hear fine differences (although I think that is partially down to a lack of huge numbers of comparisons). However I'm not saying it doesn't happen - in fact I'm sure it does. I'm not sure you could even measure such differences. I would go as far as saying that I'm GLAD I can't hear it - because I spend less time perfecting everything - before deciding it's a dead loss and starting again!
Anyway, my excuse for trying to make nice looking equipment is presentability & good engineering. I think most CD recordings nowadays are fairly mono & 2D anyway.
Just my 2p worth.
Gaz
Old 26th July 2003, 11:00 AM   #44
diyAudio Retiree
Default Re: Re: Engineering post
You followed that idiots advice? I do very seriuosly recommend trying the Wonder wire from M Percy though. It is a very good a neutral wire used by Counrtpoint and Steve McCormak and has the mechanical properties and solderability you need.
Wonder Wire: A proprietary design high performance 19ga solid core, silver clad high purity copper with a unique crystal structure, uninsulated
www.percyaudio.com
Warning extreme hyperbola alert but WTH:
http://members.aol.com/trtwonder/
Old 26th July 2003, 11:20 AM   #45
diyAudio Senior Member
fdegrove's Avatar
That may well be true but they don't seem to tell us much about any of their products.
THE WONDERPEOPLE
Frank
Old 26th July 2003, 11:46 AM   #46
Account Disabled
Oh... I played golf today with a man who works about industrial vibration. He is a PHD. He said if something is inside water, its natual resonance frequency is lowered because the water acts as added mass, i.e. according to (k/m)^0.5, where k is stiffness and m is mass.
Hello... am I in the right place?
Old 26th July 2003, 01:35 PM   #47
grataku is offline grataku  United States
Yep!
INFINICAP: where's the patent?
there are a handfull of ways to pull a thin metal film, to metallize polyprop. and most definitely one way to make polypropylene in high yield in a chemical reactor.
Add to that only a handful of capacitor winding machines types.
I am not going to say who but I found a place where they claim to be using a process I used at work a few times to produce certain components and I saw NO sign of that process being used on their pictured final product.
This is not politics it's science and technology. Things can be proven right or wrong. Most of them today, some of them in the near future. I don't understand why debating this simple thruth.
Old 26th July 2003, 02:51 PM   #48
Default Re: Re: Re: Craftsmanship and engineering
Originally posted by millwood
The answer is absolutely "yes", unqualified.
But, can you hear the difference?
Sort of my underlying point...
-With a bad amp, everything sounds the same. It takes a good amp to tell the difference between true "Artists" and the rest of the "Performers".
Old 27th July 2003, 12:09 AM   #49
Account Disabled
THE WONDERPEOPLE
could it be that there IS nothing to tell and those guys are being honest?
Old 27th July 2003, 12:27 AM   #50
fdegrove's Avatar
Meaning what exactly?
Or are they just bringing money to the bank?
Cheers banker...???
Frank
Engineering quality Lars Clausen Everything Else 10 25th November 2004 11:29 PM
Copyright ©1999-2013 diyAudio
