Craftsmanship and engineering
Old 25th July 2003, 07:07 PM   #11
Beggar is offline Beggar  United Kingdom
Beggar's Avatar
Originally posted by seangoesbonk
I changed all the capacitors in my microwave to Black Gates, and now all my food tastes WAY better!!! Hooray!
Lol nice one dude,
Yeah i think that everyone is different, how people percive minor changes to an amp etc are going to vary from person to person, and to be quite frank let them!
Personally i am really happy that i cant tell the difference between tiny changes in amps, means im less fussy and dont worry about things too much, but really this is a case of live and let live
Well thats my thoughts on the topic
Old 25th July 2003, 07:19 PM   #12
millwood is offline millwood  United States
Account Disabled
and I heard that those BG caps make hotdogs taste like deep sea shrimps.
Old 25th July 2003, 07:38 PM   #13
Lisandro_P is offline Lisandro_P  Argentina
Lisandro_P's Avatar
Send a message via ICQ to Lisandro_P
Personally, i care for looks almost as much as the sound. In fact, i've always had a pretty good idea on how i want something to look like long before touching a solder gun, and spend quite a lot of time on paper to know exactly how to arrange things how i like. For example, right now i'm in the final stages of a DoZ for headphones, which is a small steel box with a cooper front. I had to do a LOT of thinkering to fit two boards, a sink, a transformer and all the connectors in there, and i'm not even done yet.
Still, i always try to use quality parts, partially for the sonics (you won't find tantalum caps in an amp of mine ), but mainly because they're simply of better quality - this translates into longer life. OTOH, i also use a lot of recycled parts... this DoZ uses some poly caps and connectors from broken computer PSUs, and that's just the amp board itself.
Old 25th July 2003, 07:40 PM   #14
dkemppai is offline dkemppai  United States
Default Re: Craftsmanship and engineering
Originally posted by Gerontius
How could oak v. maple possibly make a difference?
You can't hear a difference between a wood and maple case or an amp suspended by a single madagascarian silk fiber in a vacuum.
2 inches of hookup wire in a case or 2 feet of hookup wire in a power umbililical can't, and do not, have a "sonic signature". They just don't.
My advice is to get a basic electronics book like "The Art of Electronics" by Horowitz and Hill.
Oak and maple have different mechanical properties, if excited by an impulse waveform, would they vibrate differently? If so, would they damp differently? Would they sound be different? Is it possible that the sound in a room could cause the case of the amplifier to vibrate? If so, would this blend in a good or bad way with the sound of the speakers?
Silk suspended amp... ...could sounds in the music excite the silk string, causing vibration? Thus exciting other sounds?
I have seen where the length of a wire changing by more than a few inches caused a device to operate or not. Could inductance by the added length of wire, or resistance change the circuit enough to cause instability? Would poor PSRR combined with wire layout cause feedback? Could this feedback be damped, where it would only cause a damped oscillation, adding the spectrical content with only high slew rate signals and not pure tones. Would this sound differently, depending on the music?
Horowitz and Hill page 712 address care about cables for a digital system. (If a computer cares about crosstalk in a cable, I would think an analog amplifer would care even more!)
I have seen circuit boards, with different layouts operate differently, even when they contained the exact same circuit.
Why is this, after all the IC's were identical, and the designers made them to be the best they could be!The "The Art of Electronics" is just that, and Art. Not an exact science. As much design goes into a good board layout, and good cabinet design, as does a good circuit design.
The point is, it's good to be skeptical, but it's also good to keep an open mind. If it sounds like B.S., take it with a grain of salt, but don't dismiss the idea completely. Ask yourself some quesitons. How?, Why?, What if? You may be surprised.
Food for thought!
-Dan
P.S. Anyone every build the same speaker cabined out of solid wood, vs particle board and compared the sound?
-With a bad amp, everything sounds the same. It takes a good amp to tell the difference between true "Artists" and the rest of the "Performers".
Old 25th July 2003, 08:13 PM   #15
Account Disabled
Default Re: Re: Craftsmanship and engineering
The answer is absolutely "yes", unqualified.
But, can you hear the difference?
Old 25th July 2003, 08:44 PM   #16
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Interesting, i don't insist preaching to the deaf, but why are they so insistent in making us appear deaf too?
Old 25th July 2003, 08:53 PM   #17
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
How is he making anyone appear deaf? He simply asked if it was audible. A reasonable question given that not all that we might perceive is due to actual audible stimulus.
By the way, why are you insisting that others are deaf?
se
Old 25th July 2003, 08:55 PM   #18
On Hiatus
SY's Avatar
Come again?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th July 2003, 08:57 PM   #19
analog_sa's Avatar
Am i? I know you are not, but you won't be caught dead sharing a subjective experience, right? As it doesn't tally well with the theory
Old 25th July 2003, 09:00 PM   #20
faustian bargin is offline faustian bargin  United States
subjective experiences tally perfectly well with psychological theory. i think that's the point.
Craftsmanship and engineeringHide this!Advertise here!
Engineering quality Lars Clausen Everything Else 10 25th November 2004 11:29 PM
