Old 23rd January 2011, 02:12 PM   #1
DreadPirate's Avatar
Default LM3875 Basic Questions
What is the orientation of optional Ci (specified as 22uf) in the basic configuration recommended by national? Positive to ground?
http://www.national.com/ds/LM/LM3875.pdf
Old 23rd January 2011, 05:44 PM   #2
Ideally, there is zero dc across the capacitor so it doesn't matter. In practice there will only be millivolts on it so put it in any way you like.
Old 23rd January 2011, 06:05 PM   #3
the input offset current * the input Rin results in a voltage across the DC blocking cap and across the RF attenuation cap.
If the output offset is exactly zero then this same capacitor voltage appears across the DC blocking cap in the NFB loop.
It varies with the chip but can be anywhere between 20mV and 300mV.
It should be measured after building, to check that orientation is correct.
regards Andrew T.
Old 23rd January 2011, 07:04 PM   #4
Kinnja is offline Kinnja  United States
If you are going to use an electrolytic here, then generally speaking, connect the side marked with the minus signs to ground. If you are using a film, or a bipolar electrolytic then it doesn't matter.
Some basic questions..... astrodog Chip Amps 5 2nd July 2008 09:18 AM
Some basic questions about Q wigginjs Multi-Way 8 20th October 2004 07:22 PM
Basic Questions DarkMage Multi-Way 2 5th November 2003 02:51 PM
Some basic questions... Ziller Everything Else 5 13th January 2002 02:49 PM
Basic Questions wnichol Solid State 4 16th November 2001 04:59 AM
Page generated in 0.38312 seconds (15.01% PHP - 84.99% MySQL) with 10 queries
