| Chip Amps Amplifiers based on integrated circuits |
I have used many times ceramic cap 0.1uf across the +- rails for opamps & power amps. Today it burns with fire. What must be the reason ? I am using 15-0-15 90VA transformer with split power supply.
Regards. |
#2 |
Excessive power dissipation
![]() Check ripple current and ESR.
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken |
#3 |
Check the voltage rating. 15-0-15 AC leads to 42 V DC from rail to rail. Add 15 % transformer regulation to that -> 48,3 V. Then add 10 % mains fluctuation -> 53,13 V. The caps should have a 63 V DC rating or higher.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#4 |
Are you sure it wasn't a tantalum cap?
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#5 |
#6 |
If you're using a disc type ceramic , which what you'll get if you're asking for 0.1uf in India they aren't suitable for bypassing at high voltages. They are rated at something like 63VDC. Ask for 0.1uf poly caps and you'll get a polyester cap with 100VDC rating which should work fine. If you get a box type cap the voltage will be clearly marked on the box itself, these can be used easily for bypassing . If you've not measured your trafo output, I'm sure it's putting out a lot more than it says i.e it might be actually like 18-0-18.
#7 | |
Thank you,
#8 |
Capacitors block DC and pass AC, so assuming it was rated for that DC voltage, the heat must be from ripple current or some other source of AC. You could also just have had the bad luck to have a bad capacitor, I suppose.
#9 |
Wait, tantalum capacitors should not be used for decoupling? Why not?
#10 |
tantalum caps make good decoupling caps. That's why they were recommended and used extensively. But continued build experience has shown them to become unreliable and usually by going short circuit. As far as I am aware, reliability alone is the only reason for avoiding tantalum caps.
regards Andrew T. |
| Preffered film caps to replace ceramic caps? | rg12 | Parts | 20 | 2nd September 2010 04:35 PM |
| 200V ceramic caps | AndrewT | Parts | 2 | 22nd April 2005 02:11 PM |
| Replacing ceramic caps - do or don't? | Cradle22 | Solid State | 4 | 16th March 2003 12:39 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 01:02 PM |
| Why different kinds of ceramic caps? | sam9 | Solid State | 4 | 24th September 2002 03:48 PM |
| Page generated in 0.10236 seconds (81.07% PHP - 18.93% MySQL) with 10 queries |
