| Chip Amps Amplifiers based on integrated circuits |
I have a non inverting stereo kit with a psu board for each side. My transformer is a single 25-0-25 330VA with dual secondaries. I think I read somewhere that I would be better off going with a single psu board. My psu boards have allowance for seperate rectification (3 pin shottkeys for each side), but would share the caps. If I did this, I would use 4 x 2000uf Panasonic FCs. Is this optimal, or should I use both boards and place 2 x 2000uf on each?
#2 |
I would feed the two amp boards from this single board.
#3 |
Yes, that would work fine. I wrote about it here: Commercial Gainclone kit- building instructions
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
| build your super LM3875 amp! | lanchile | Swap Meet | 8 | 7th April 2010 03:19 AM |
| Need advice - 25 volt transformer with LM3875 | commoncollector | Chip Amps | 4 | 26th February 2009 04:24 AM |
| I was going to build my GC LM3875 but... | lanchile07 | Chip Amps | 4 | 23rd June 2008 01:15 AM |
| Advice on how to start a LM3875 amp project | fatbob | Chip Amps | 12 | 8th April 2008 03:15 AM |
| 3 channel lm3875 help/advice | Tristanc1 | Chip Amps | 8 | 22nd January 2007 05:04 PM |
| Page generated in 0.06314 seconds (67.54% PHP - 32.46% MySQL) with 11 queries |
