Controversy regarding Bridged Amplifier power output - Page 10 - diyAudio
Old 31st May 2012, 04:59 PM   #91
Bridging 2 similar amps will certainly produce 4 times more power into a load than what an individual amp produce into the same load seperately...! The term "4 times more power" must be seen only as the ratio what a load get when connected in bridge to what it get when conncted single endedly. Dont compare the total power of two single ended load to one bridged load. However, the fact stand true only if ;-
1.The power supply is capable to maintain its rail voltage at increased (double) current demand.
2.The output stage of each amp in the bridge is designed to handle half of the nominal single ended impedance.
Old 22nd November 2012, 05:27 PM   #92
I can't follow stevensoosai2527's argument too well until items 1 & 2 which, as a X2 power person, I agree with. But such an amp must be rare. It would be capable of operating safely, without distortion or risk of smoke at double the spec on the label.
Consider the replies if someone posted on this forum the following question.
"I have a 100w RMS MAXIMUM amp - into 4 ohm MINIMUM load. Can I get 200w RMS by using a 2 ohm speaker ?"
Or muse over this. A 100w/4 ohm amp could be considered to be a 100w, 20v rms ac generator. But if you had two 120v ac, 1Kw petrol generators and connected them in series (and synchronize them appropriately) would you have a 240v 4Kw generator ?
Does not common sense tell you the answers ? It's a case of not seeing the wood for the trees methinks when bridged mode comes on the scene.
If I've understood it correctly, Earlier in the thread it was suggested that a bigger transformer might help an amp reach X4 power. In my, admittedly limited experience, amplifier output transistors/chips are the most critical, vulnerable components.
Finally, an apology for resurrecting an old thread but I read all 91 posts with interest. A thread which started with a quote from Wikipedia which had it right to start with.....Well I would say that wouldn't I...I wrote it
Power Amplifier Output Topologies danville Solid State 58 7th March 2010 06:40 PM
Class D amplifier Power Output ndsonu Class D 6 28th October 2009 05:08 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
41Hz.com AMP8 - Output power when bridged MikeHunt79 Class D 8 29th March 2008 02:47 PM
Power Amplifier Output Protection kosalev Solid State 2 16th November 2007 12:39 PM
Copyright 1999-2017 diyAudio
