| Chip Amps Amplifiers based on integrated circuits |
Hey,
I've built LM3886 I ordered from chipamp.com. It has been working fine for couple months now. I'm satisfied with the sound, but still I have question. Wiring from chip to speaker connections is now made with thin wire. Both positive and negative are 0,25mm. Is this too thin? Board has holes for 1,5mm cable. I have 1,5mm cable (solid) and 1,1mm cable (stranded). Should I change this wire? Solid or stranded? Do you think I'll hear the difference
#2 |
Changed wire to solid 1,5mm. Don't know can I hear the difference, but it's not worse. Better bass with less volume? I thought this change would affect only with higher volumes.
#3 |
how short are your PCB to speaker terminal wires? How much resistance do they have? Have you twisted them? Have you listened yet?
regards Andrew T. |
#4 |
Length is about 20cm. I don't know about resistance. Didn't measure. They are twisted. They sound pretty much the same, but I think there is better bass now with lower volumes.
#5 |
Banned
Basically the thicker the better and solid is better than stranded.
2.5mm UK Mains ring main cable is ideal and easilly available and affordable. As your speaker has an impedance of approximately 6 Ohms at bass frequencies, any resistance in series with the output of the amplifier will attenuate the bass. |
#6 |
#7 |
Theoretically current can go from one strand to another strand making many different pathes through strand surface that could vary total wire resistance withing short period of time that can be considered like noise. How it can affect sound in a real device questionable of course.
Solid wire means being on a safe side. Litzendraht is another extreme. I vote for solid as well. |
#8 |
The wire shouldn't be any smaller than the leads coming out of the chip.
The chip output leads were obviously designed to handle the output power of the chip. |
#9 |
For the length of those leads. You can't arbitrarily say this diameter wire will hand this amount of current. You need to include length.
Tyler |
#10 |
that stranded is better than solid.
| wiring | trai1824 | Multi-Way | 24 | 17th February 2008 11:33 PM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.09892 seconds (79.12% PHP - 20.88% MySQL) with 10 queries |
