Old 21st January 2011, 07:11 PM   #11
frank1 is offline frank1  United Kingdom
Default I've always heard... that stranded is better than solid.
You heard wrong!
Old 21st January 2011, 07:13 PM   #12
Originally Posted by suntechnik View Post
Theoretically current can go from one strand to another strand making many different pathes through strand surface that could vary total wire resistance withing short period of time that can be considered like noise. How it can affect sound in a real device questionable of course.
Solid wire means being on a safe side. Litzendraht is another extreme.
I vote for solid as well.
This is utter rubbish. Sorry
Litz wire is not the same as stranded. Each strand is insullated.
Don't forget, we are talking about AUDIO frequency here NOT RF.
Old 21st January 2011, 07:24 PM   #13
Absolutely agreed!
Old 22nd January 2011, 05:42 AM   #14
tangmonster's Avatar
How big is skin effect at audio frequencies?
Old 22nd January 2011, 06:41 AM   #15
Negligible. Especially for a length of 20 cm.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 22nd January 2011, 07:01 AM   #16
liquias is offline liquias  Israel
Default How come ?
Please consider this link:
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies
Due to skin effect I too always knew stranded is better ...
Also I have seen allot of very professorial speaker cables which are stranded and I have never seen any solid conductor speaker cable.
How come skin effect is negligible ?
And what does skin effect has to do with a wire's length ?
Old 22nd January 2011, 07:16 AM   #17
AVE...
1.5mm stranded wire will be enough...
At audio frequencies skin effect can be ignored - in case of stranded wire each strand will conduct the current with it's whole diameter...
You will hear the difference because the original wire you used was too thin and had considerable resistance and voltage drop across it's length. Next time consider the maximum current flowing through the cable and select proper wires...
Old 22nd January 2011, 07:30 AM   #18
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Wouldn't that only be an advantage if the strands were insulated from one another?
I use Cat6 - that's solid core. I'm not the only one. Stranded speaker cables are popular because they're more flexible. Multiple thinner solid cores in parallel helps fix this drawback.
It pretty well is at audio frequencies unless your cable is a fairly thick one. Even then, inductance would probably be more of a concern than skin effect. It certainly is in speaker cables.
I can't think - its only related to the diameter and the magnetic permeability of the conductor I thought. Perhaps pacificblue made a mistake?
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Old 22nd January 2011, 07:34 AM   #19
Banned
As the LM3886 is a far stretch away from Hi-Fi in the ultimate sense, it doesn't make much difference and stranded is more manageable.
Old 22nd January 2011, 10:23 AM   #20
AndrewT is online now AndrewT  Scotland
the skin effect is dependent on the apparent increase in resistance of a conductor when higher frequencies are passed through the conductor.
the resistance of any wire is proportional to it's length, it's conductivity and inversely proportional to it's cross sectional area.
LENGTH must be taken into account.
Would someone care to calculate the skin effect on a 0.6mm diam copper wire feeding 1Apk along 100mm of conductor to an 8r0 load, at 10Hz, 100Hz, 1kHz, 20kHz and 100kHz?
The answers will be instructive to all.
wiring trai1824 Multi-Way 24 17th February 2008 11:33 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.10630 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
