| Chip Amps Amplifiers based on integrated circuits |
I wondering if it possible to have a BTL output on STK412-110, STK4231II, OR STK412-130 at 4 ohms? Has any one tried this, the datasheet didn't say weather or not it can run in BTL mode or 4 ohms
#2 |
Most of the older STKs are designed for 8 Ohm operation. In BTL configuration they see half the load. A 4 Ohm speaker will appear as a 2 Ohm load to each of the ICs. You can make up for the lower impedance by reducing the rail voltage, but that reduces the available output power accordingly and makes the BTL effort absurd.
With a 4 Ohm load it appears more promising to use two channels in parallel, if for some obscure reason the power of a single channel should be insufficient.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| Need help with buying WM8740 ics | Wynand | Digital Source | 4 | 9th June 2006 02:29 PM |
| New to ICs question........ | amperex | Parts | 6 | 23rd February 2006 08:32 PM |
| What wire are you using in your ICs? | DJNUBZ | Parts | 2 | 20th December 2005 04:50 PM |
| Composite ICs | 00940 | Chip Amps | 3 | 18th December 2005 05:52 AM |
| DIY ICs | Vivek | Everything Else | 28 | 26th July 2002 07:50 PM |
| Page generated in 0.06937 seconds (69.47% PHP - 30.53% MySQL) with 10 queries |
