| Chip Amps Amplifiers based on integrated circuits |
Okay just installed a brand new LM3886 into one of the chipamp branded PCBs, I have a +/-30V supply in all the right places but I have no life, nothing on the output no hum no audio out it's stone cold never gets warm nothing like it's not turned on but I have measured the voltage off the board. Do I have a dead LM3886?
I thought about it once, but then thought again. |
#2 |
mute pin?
#3 |
It's the chipamp boards they don't have a mute pin option.
DIY Chip Amplifier Kits, PCB's, Components and Information. At least I thought they didn't and there's no where on the board for it.
#4 |
post schematic and photograph.
regards Andrew T. |
#5 |
#6 |
just power up your chip and measure voltage on pin 8.
It should measure -30V |
#7 |
Banned
Check and Double Check your work compared with the instructions as board has a number of options that are implemented by varying the positioning of some components.
Check amplifier wiring to external circuitry iaw instructions. The LM3886 is quite robust but will be damaged by overheating if you are too slow when soldering it to the board. Also momentary misconnection of + & - supplies will destroy it. |
#8 |
Banned
It might sound daft but have you connected PSU 0V to Pwr Gnd and SPEAKER -ve to PSU 0V.
Have you connected input between Sig and Sig Gnd. I've seen it before where, because they're not shown on the diagrams, the 0V connections have been omitted. You may hear a slight HISS from the speaker. It'll be very quiet though. |
#9 | |
#10 |
Banned
If you have inadvertently misconnected + & - any electrolytics on the amp board may be damaged. The IC will certainly be fried.
There are also fake LM3886 chips out there. |
| signs of a dead lm3886 | Ted205 | Chip Amps | 6 | 4th February 2010 03:59 PM |
| My Lm3886, Dead or not? DC at OUTPUT! | mathieujohnson | Chip Amps | 8 | 29th June 2006 09:19 PM |
| dead project, new life? | yosh | Tubes / Valves | 4 | 24th March 2005 05:24 PM |
| Page generated in 0.09284 seconds (77.80% PHP - 22.20% MySQL) with 10 queries |
