| Chip Amps Amplifiers based on integrated circuits |
Hello all
I recently got this amp very cheap... So im interested in replacement for STK2038B coz this original one is not working... I couldnt find that chip here on the market (Serbia) All i was able to find is STK2038 IIcl so im wondering can i use it as a replacement? Thanks! |
#2 |
According to this: [TechAssist] Re: looking for STK2038 (or 20x8) pinout or datasheet - techassist - FreeLists , you can't ( different number of pins and probably pin-out ) it's probably easier to build a new amp module with an ic that has similar voltage requirements and power output.
#3 |
The STK 2038 is notorious for failure, and when it does it often takes the voltage amp IC, AN7062 with it.
These amps are nothing particularly special to be honest. |
#4 |
Ye i know
Since im beginer in audio electronics i alrdy managed to fix one hitachi amp with STK ic... This Technics amp was one of many i mean realy many fail amps with STK hybrid inside... So for start of my electronic experience all i can say is run away from STK amps as far as u can! |
#5 | |
i own this model amp..too. but deth ic... i replace new amplifier stk4231 ic with new board to add and some alter and find i/o con output to stk4231 amp very nice.... and increase caps 10000mfd 63v per rail works very fine. |
#6 |
Banned
cricklewoodelectronics.com list the STK2038 II but I have no idea if this is the same as the STK2038B.
#7 |
I have the same problem on Technics SU-V2X, I have ordered the STK2038 but i'm not shure if it is pin compatible with the STK2038IV. Does anyone have a datasheet of the STK2038 ? What is the best replacement ? I would like to have class A or Technics new class A output stage. Any suggestion ? |
#8 |
Works, I have replaced the STK2038IV with STK2038, no change on the mainboard of the SU-V2X
| Is STK2038B the output stage for Technics SU-Z55? | AX816 | Chip Amps | 5 | 14th March 2011 05:08 PM |
| technics SU Z45 | b0ssmanracing | Solid State | 5 | 9th March 2010 11:05 AM |
| old technics SU-Z400 | cutcat | Swap Meet | 1 | 27th December 2006 12:53 PM |
| Re: Technics SU-9070 | MazdaBoi | Solid State | 9 | 14th February 2006 10:58 PM |
| Technics SU 7600 | Ford_V6 | Solid State | 0 | 25th May 2004 02:28 PM |
| Page generated in 0.09789 seconds (69.63% PHP - 30.37% MySQL) with 10 queries |
