Old 17th January 2011, 04:19 PM   #1
ads2 is offline ads2  France
Default Dual Mono boards with only one transformer.
Hello,
I have the Dual Mono boards (2 PSU and 2 amplifiers) from Brian Gt.
Finally I decided to buy only one Transformer 2x25V 300VA.
Does it make any improvement if I use the 2 PSU boards instead of one, with only one transformer ?
each PSU board have 2 caps of 10.000uF.
Armindo
Old 17th January 2011, 06:02 PM   #2
It comes down to an improvement in the bass region vs. a higher likeliness of ground loops.
You could use one power supply with double the capacitance.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 17th January 2011, 10:23 PM   #3
I'm not an expert, but it seems that the best success is a 1:1 of trafos to PSU boards.
it seems ok to have multiple amp modules draw off the same PSU board but having multiple PSUs on one set of diodes or 1 trafo could cause ground loops.
like PB said, double up on the bulk storage caps on the central PSU.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 18th January 2011, 07:16 AM   #4
Thanks for your reply.
How do I double ? should I put the caps in serial or parallel ?
Old 18th January 2011, 07:28 AM   #5
sandyK is offline sandyK  Australia
I can't speak for chipamps, but I had been running a dual PCB Class A HA from one PSU and a single JLH PSU addon , then I changed to dual PSUs and dual JLH PCBs running off a single outboard 18-0-18 30VA transformer. There was an improvement in soundstage etc.
Later, a friend (DIYAudio member) told me that he had even better results when using dual transformers as well. Eventually, I did what he suggested and changed to dual mono type construction. There appeared to be a further improvement in channel separation, and as my friend suggested, ït just sounded more "right"
Sandyk
Old 18th January 2011, 07:44 AM   #6
Sandyk,
Dual mono was what I planed to do first, but my problem now is double :
- cost of 2 transformer
- my case is only 230x280 mm, and not a lot of space...not sure it would be safe to put the boards very near to transformers.
Old 18th January 2011, 05:09 PM   #7
In parallel.
Old 18th January 2011, 06:32 PM   #8
thanks Pacificblue
Old 19th January 2011, 11:17 AM   #9
if you use a centre tapped transformer for your single Bridge Rectifier then you must have ONE Main Audio Ground.
This Main Audio Ground must be shared between all channels.
This seems to have fewer problems if you have one PSU.
If you have a dual secondary transformer you can either have a single PSU & single Bridge Rectifier as above
or
using twin Bridge Rectifiers you have the option to have an Audio Ground dedicated to each channel. This requires. dual secondary, two sets of dual Bridge Rectifiers, two sets of Smoothing Capacitors and two sets of Disconnecting Network to tie in the Safety Earth.
Each channel must strictly follow star grounding and must use low loop area for all flow and return pairs.
regards Andrew T.
Old 19th January 2011, 12:01 PM   #10
AndrewT,
Hummm . It seems that there were a misundersting due to my bad English...
In fact I should have shortly a dual secondary transformer (2 x 25V 300VA). (bought it for 30 Euros delivered)
I have in my hands the dual secondary transformer, 2 amp board http://www.chipamp.com/images/lm3886amp-parts.jpg and 2 power supply board http://www.chipamp.com/diyaudio/snubber.jpg also here http://www.chipamp.com/images/ps-rev3-sch.gif
Normally, with one dual secondary transformer, we use 2 amp boards + 1 power supply board. like this http://www.chipamp.com/images/lm3886amp-assembly.jpg
But I have 2 Power supply boards (and don't plan to use 2 transformers). So my question was, instead of using only one power supply board, won't it ne better to use both power supply boards (connected to the same dual secondary transformer).
Sorry again for my bad English
Use of dual transformer for mono amp jtsaudio Power Supplies 1 20th May 2010 10:51 AM
transformer for LM3886 dual mono kit gonzalez Chip Amps 16 11th October 2008 09:55 AM
LM4780 dual mono -- boards jackinnj Swap Meet 1 1st October 2008 12:44 AM
KrellClone KSA100-MKII 1000VA toroidal transformer for dual mono GB stolbovoy Group Buys 33 16th June 2008 04:39 PM
Is this Transformer OK to use with BrianGT's dual mono kit? mattjk Chip Amps 4 22nd October 2004 11:00 AM
Page generated in 0.10159 seconds (80.30% PHP - 19.70% MySQL) with 10 queries
