Old 24th July 2003, 01:51 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default My unfinished gaincline chassis
6mm aluminium, 430x280x75mm
Here are a few pictures:
Old 24th July 2003, 01:53 PM   #2
Bricolo's Avatar
n°2:
Old 24th July 2003, 01:55 PM   #3
Bricolo's Avatar
n°3:
Old 24th July 2003, 01:58 PM   #4
Bricolo's Avatar
I'll let the plastic sheets over the plates until the chassis is completely finished. This will avoid scraches when I'll work on it.
Any comments?
Old 24th July 2003, 02:20 PM   #5
Account Disabled
Originally posted by Bricolo
Any comments?
she is a beauty.
where did you get the aluminum plates and how did you work on them?
Old 24th July 2003, 02:44 PM   #6
Bricolo's Avatar
I bought the plates from a company that works with aluminium, near strasbourg
I drilled the holes with a (don't know if it's the correct word in english) stand-driller (a big driller on a stand). Holes are 5mm, with a chamfering for the screws
the "inner holes" were drilled with 4.2mm and then I made a M5 tapping
Old 24th July 2003, 02:53 PM   #7
Bricolo's Avatar
now I'm wondering how I'm going to place all my gainclone's components in it
should I place the toroid in the center, ant then each channel at one side?
or place the toroid in an edge or a side?
Old 24th July 2003, 03:01 PM   #8
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I would place it in a center.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th July 2003, 03:08 PM   #9
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
As I have just written on another thread...
Absolutley stunning! People are actually catching up with PD's standards! (I'm just trying to nudge him into doing something outstanding! )
Keep up the great work and pictures. The name for the drill you were using is called a Pillar Drill.
Gaz
Old 24th July 2003, 03:09 PM   #10
Bricolo's Avatar
OK
Peter, any comments about my case? I know I'm still far from your artwork skills, but I'd like to know what you think about my first chassis.
The problem I've got with it (the only one for now):
the top (and bottom) plates are "inside" the others, not other and under. I did it because of aesthetics, this way when you look at the amp (in front of it) you only see the front plate, ant not the front plate with the left/right/top/bottom plates all around of it.
but I have difficulties to put the top plate off, it's strongly hol in place by the other plates when they are screwed
unfinished gainclone merlin2069er Swap Meet 0 8th December 2008 05:42 PM
F3 unfinished project for sale hc167 Swap Meet 5 27th September 2008 07:36 AM
Gaincline Bi-Amp / Active Crossover - work in progress gainphile Chip Amps 10 5th January 2008 11:35 PM
fs: unfinished gainclone MERLIN2049ER Swap Meet 10 19th February 2006 01:49 AM
Phodies of my unfinished projects. Bas Horneman Everything Else 4 30th January 2004 07:20 AM
Copyright ©1999-2013 diyAudio
