| Chip Amps Amplifiers based on integrated circuits |
I am going for the Audiosector alternative as an integrated amplifier.
It will be a crude thing mounted in a very old steel fuse box (wall mounted). I would like to have an ampere meter above the Russian 35-step switched attenuator with a large gray knob. The thing with the attenuator is that it has only one contact per channel, forcing me to connect the resistors in serial. Would you recommend I used it for this amp? Also, actually getting the steps right (70 dB gain = 2 dB per step) I guess could be a challenge in the right quality resistors. Has anyone tried this? |
| need help new to building | bostonswoop | Subwoofers | 19 | 28th January 2006 01:15 PM |
| building new sub | pjpoes | Subwoofers | 3 | 7th September 2005 09:45 PM |
| Should I even consider building | wad06 | Subwoofers | 25 | 28th January 2005 02:52 AM |
| Building: Need Help | ICARE | Tubes / Valves | 19 | 6th June 2003 11:32 AM |
| Page generated in 0.05118 seconds (67.71% PHP - 32.29% MySQL) with 10 queries |
