| Chip Amps Amplifiers based on integrated circuits |
I'm getting the parts together for Mini, Low volume, good quality "can you go and do that somewere else please" Guitar amp.
The plan so far is to build a clean power stage first, based on a TDA7375 driving a 4Ohm 6" Jensen Speaker. The first thing I like to do on these builds is figure out the power supply; I'd like to regulate it on board so I can use a veriety of power sources. If I'm reading the TDA7375 data sheet right, I could be looking at a current draw of over 4A at peak. If this is right my usual 78XX regulators arn't going to like it. High Current regulators are expensive beasts; Can anyone sugest some options for a Cheapy regulated supply that can drive this chip? |
#2 |
There are shematics how to increase the 78XX's current in the datasheet on page 17 and 18.
One alternative is a more expensive regulator like the LT1083 or LT1084.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 | |
Pass transistor regulators are pretty common...if you look into LM317 data sheet you'll find lot of designs. Performance wise surely an integrated regulator like LT1083 will definitely be better but a pass transistor design will not be all that bad either..considering the cost. |
| TDA7375 Build | whammoed | Chip Amps | 4 | 9th June 2010 04:28 PM |
| Help with tda7375 | Nenola | Chip Amps | 7 | 3rd March 2009 02:15 PM |
| I need help on TDA7375 | ahonda55 | Solid State | 6 | 2nd July 2007 08:34 PM |
| TDA7375 as a subwoofer amp | JAZZ2250 | Chip Amps | 5 | 18th May 2005 05:31 PM |
| Voltage regulator help! | kasra | Solid State | 7 | 23rd November 2002 02:07 PM |
| Page generated in 0.07039 seconds (71.37% PHP - 28.63% MySQL) with 10 queries |
