Arcam Alpha 8 conversion from 220v to 115v
I want to change my Arcam Alpha 8 amp back to run on 115v. I switched it to 220v while I was living in the UK but now back in Canada need to switch it back to 115v. Except I forget what the original fuse arrangement was. It's presently configured for 220v. There are 2 fuse holders located behind the power switch. The fuse holder closest to the front panel has a fuse in it. The holder behind is empty. There is also what appears to be a spare fuse sitting in a little clip nearby. Do I simply move the fuse from the first holder to the second? Or do I add the spare fuse to the empty fuse holder? Anybody know? I emailed Arcam but they're taking their time in responding! Thanks! Joel
