| Chip Amps Amplifiers based on integrated circuits |
This PCB design of LA4628 is as per as the datasheet of this IC. It is done through Diptrace software. Diptrace analysize its correct and it shows "no errors found". So can you tell me whether it is correct or not ?
Thank you ! Have a good day ! |
#2 |
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 | |
The trace from pin 11 is crossing the traces from pins 13 and 14, leading to shorts may be need to redraw it as Diptrace is not showing any shorts. I keep pin 4 non-connected as I don't like to use mute. I don't know how to unmute the amp can you tell me ? What is the star point that you mean ? The trace width for current flow is keept for upto 1 amp current flow only as if need in future I will add 0.025 point to make it wider. Component sizes are great headache for my amp as I like to keep size of PCB within 2" X 2" maximum due to space. |
#4 | ||
The point where all ground connections meet. Normally either on the power supply board next to the smoothing caps or on the case where the PE enters. Quote:
You won't get rid of the headache by drawing components smaller than they actually are. It will also not help, if solder pins overlap with components or are so near to each other that you cannot solder them without producing a short.
#5 |
Pacificblue,
Thank you for your reply ! Here it is the revised PCB of LA4628 as per your advices for you judging it. Again Thank you ! Last edited by pixnum; 16th January 2011 at 06:17 AM. |
#6 |
Interesting star point. You can make that much smaller. Add a solder point to it where you can connect the wire from the power supply.
I don't think your amp will play when pin 4 is connected to ground through a resistor. The datasheet sepcifies a 5 V signal there. You still use the same sizes for all caps. U1 and U4 seem to slightly overlap. U3 looks as if it could be overlapping with the amp chip.
#7 |
#8 |
You don't need a 5 V signal at pin 4. You need a signal of 1,5 zo 3 V. The datasheet shows how to achieve that with a 5 V input. For a higher supply voltage you need to increase the series resistor.
You could use a trimmer, set it to the highest resistance, connect one end to the supply voltage and the wiper to pin 4. Turn it slowly down until the amp switches on. Then measure the resistance that is set on the trimmer and replace the trimmer with a resistor of the next lower value. Depending on the supply voltage the trimmer should have 100k up to ~18 V supply voltage. More, if the supply voltage is higher.
#9 |
pixnum; You need to look at the data sheets for these chips, thay will tell you all you need to know. The books that just post schematics from the data sheets without any explanations on how thay work either assume you have some back ground or are vary poor sources of information.Andy
| Schematic: Audio Innovations, The first audio amplifier | maartentje | Tubes / Valves | 22 | 25th February 2010 06:34 AM |
| Audio amplifier | Darksog | Solid State | 26 | 18th January 2006 02:17 AM |
| Audio Amplifier | VoLCoM | Chip Amps | 2 | 9th July 2005 01:42 AM |
| audio amplifier | mephisto | Car Audio | 2 | 21st January 2004 04:52 AM |
| Page generated in 0.11600 seconds (82.97% PHP - 17.03% MySQL) with 11 queries |
