Old 13th January 2011, 10:54 PM   #1
Default [TDA7294]Building my first chip amp
Hi guys,
as I have already written in the wrong section of the forum (my bad ), I'm going to build a chip amp based on the IC TDA7294V for a school project (and maybe later convert it into a dockstation or something like that). I have already built a couple of chip amps using spare parts desoldered from old cd-players, but this is the first time trying something more "serious". Surfing the web for infos I found an incredibly simple project by "Mustafa Dere" (Tda 7294 100w peak -70w rms) that seems to suit my needs, what do you think about it? Has anyone a schematic for it (since the one posted on that page doesn't really seems to match the PBC)?
In case I wanted to follow the schematic printed on the official datasheet of the IC, could I just skip the pins 1, 9 and 10 since I don't need the mute and standby functions? And (last question, I promise ) what's the difference between "Vs (Power)" and "Vs (Signal)"?
Sorry for my stupid questions, but I really am new in this "field" . Thanks for all the help you may give me!
Old 14th January 2011, 05:51 PM   #2
The only difference between Mustafa Dere's schematic and the datasheet's is the addition of an input blocking resistor and a few different component values.
You cannot skip the pins 1, 9 and 10, because the amplifier won't work without them. No signal on those pins means amp muted and in stand-by.
The distinction between power and signal supply voltage is only necessary for the so called high efficiency application. In that case you have two supply voltages. The signal supply will always be connected to the high voltage, while the power supply voltage will be connected to the low voltage most of the time and only be switched to the high voltage during high power demand. For your application they should be connected together as shown in the datasheet.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Chip amps for sale : tda1514a and tda7294/6 rrrremus Vendor's Bazaar 0 19th October 2010 03:33 AM
help in building TDA7294 sexya Chip Amps 67 10th July 2010 02:31 PM
Need some help building a chip amp KnightofAwesome Chip Amps 3 28th March 2010 06:50 PM
chip amp building on payday stuman Chip Amps 22 14th December 2007 02:51 PM
A few questions about Building a LM3886 Chip amp??? Minion Chip Amps 21 13th October 2006 08:01 PM
Page generated in 0.07200 seconds (68.11% PHP - 31.89% MySQL) with 10 queries
