Old 12th January 2011, 05:19 PM   #1
maurycy is offline maurycy  United States
Default Soldering wire to pots thru PCB?
I always have a trouble soldering wires to small pots. Just recently I have acquired stereo pots that have very small pins. Do you guys know of any places that sell PCBs that would allow me to solder the pot onto the PCB and then wires (but not directly to the pot).
Thanks.
Old 12th January 2011, 05:46 PM   #2
Perfboard maybe?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 12th January 2011, 06:29 PM   #3
You could certainly improvise something, as pacificblue suggests.
Hifidiy.net has these....
Old 12th January 2011, 07:12 PM   #4
Thanks to all who replied. Forgot to mention that those are Alps 09 type pots so the hifidiy.net board will not fit. But this is exactly something that I am looking for. Just need a size smaller.
Old 12th January 2011, 07:19 PM   #5
Minion is offline Minion  Canada
Just use a Piece of Blank PCB material and either etch or grind the traces into it ......
Old 12th January 2011, 09:01 PM   #6
Another approach from the olden days...
Restoring Boatanchor Radios
Old 13th January 2011, 12:35 AM   #7
That's a clever idea. I actually had to click on the link to get the whole picture. Couldn't figure out what's going on from the two pictures you have posted :-)
Old 13th January 2011, 05:42 AM   #8
Especially on older, well-built gear the wires are fastened very securely before soldering. I've broken a few solder lugs and lugs on tube sockets trying to 'unsolder' components- now I use the wire spiral trick.
Old 14th January 2011, 04:08 AM   #9
how about etching the PCB by yourself?
Old 14th January 2011, 12:24 PM   #10
Since this is DIY board, I guess that's how I should do it. Unfortunately, I would spend more time and money since I have nothing that would allow me to etch PCBs.
I found this item on Ebay. Fits my pot and comes down to little over $1 a PCB.
Soldering Panasonic ECG and Similar Tight Pots DreadPirate Construction Tips 4 10th January 2010 05:38 PM
Question Regarding Soldering Cardas Wire mister pig Construction Tips 5 31st December 2009 04:56 AM
Soldering 8 Gauge Copper Wire mattthegamer463 Construction Tips 5 23rd May 2009 10:10 PM
Soldering silver plated wire? Mantronic Everything Else 4 7th January 2005 12:52 AM
Soldering wire to aluminum eRiCdWoNg The Lounge 2 12th July 2004 01:20 PM
Page generated in 0.12420 seconds (76.17% PHP - 23.83% MySQL) with 11 queries
