Old 7th January 2011, 03:59 PM   #1
Default Heatsink size adequate?
How's my heatsinking look for these LM3886? They run pretty hot I feel like.
Thanks!
Old 7th January 2011, 04:02 PM   #2
Depends on the supply voltage, the load impedance, the ambient temperature and the volume at which you listen. The obvious flaw in the photo is that there are no holes below the heatsinks to let fresh air enter. If there are no holes above them either to let hot air out, there is bound to be trouble.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 7th January 2011, 04:05 PM   #3
Supply is +/- 36 v and I'd say I'm planning to be using it at pretty loud levels a good amount. Ambient temp 75? And yeah, I should probably cut some holes, huh...
Thanks!
Old 7th January 2011, 04:25 PM   #4
infinia is offline infinia  United States
infinia's Avatar
I would also add that based on experience, with driving the amp hard, your HS size needs to be at least triple sized with added airflow esp. since you are using the isolated tabbed version. An easy rule of thumb says the chip need to get rid of the same power ( heat) your speakers are running at, so 50-60W max. About the same as powerful CPU at full tilt. Consider using the the chassis itself for a HS with added ventilation inside.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 7th January 2011, 04:30 PM   #5
Hm, I guess that might make sense to just bolt the chips onto the chassis itself...
I have a little 12v radioshack computer fan, only problem is it buzzes like heck when hooked up to a 12v rail I have going for the relays. Any way to solve this?
Old 7th January 2011, 04:45 PM   #6
infinia's Avatar
Fans and HQ audio don't really go together. Most pro gear uses a temperature sensor to control the fan speed, similar to modern PCs. Also 120 VAC fans are quieter than their DC counterparts. But consider when / if the fans fail, you would still need another form of protection too.
I think if you can use your chassis somehow that would be better.
Old 7th January 2011, 05:02 PM   #7
Originally Posted by rockgardenlove View Post
Ambient temp 75?
Centigrade or Fahrenheit?
What is the temperature of the air around the internal heatsinks. That is your ambient. For internal heatsink you could probably use Ta~40degC when the room temperature is <=25degC.
Have you used National's datasheet for sizing your heatsink?
Do that and then double the size of the sink.
regards Andrew T.
Old 7th January 2011, 05:22 PM   #8
Fahrenheit. The thing is it's a bit theoretical thus far as I'm in Oregon now and I'll be using the amp in Southern California so the weather conditions are a bit different...
I think I'll probably use the case. That's the most feasible as I'm leaving in a few days and don't really have time to source heatsinks :-/
Old 7th January 2011, 05:27 PM   #9
You should use the case and the heatsinks together.
Old 7th January 2011, 05:35 PM   #10
Wow, all that aluminum plate and no heatsink.
Yeah, mount the sinks on the other side of the plate and put the chips in the middle of the sink mounting area. May as well put the sinks as far apart as possible as well. If you do that you probably wont need any additional sinking or forced air even at 36 volts. Some vents in the enclosure (assuming you'll put a top on it) will make a beneficial difference.
LM3886 Heatsink size? henkel Chip Amps 28 11th April 2011 02:14 AM
Idea of heatsink size. littlerick Audio Sector 5 22nd April 2010 01:45 AM
Heatsink size ??? djdamix Solid State 12 14th March 2005 10:20 PM
minimum heatsink size for lm3875 mateo88 Chip Amps 2 7th June 2004 05:30 PM
heatsink size theChris Chip Amps 5 15th January 2004 07:32 PM
Page generated in 0.09887 seconds (78.02% PHP - 21.98% MySQL) with 11 queries
