| Chip Amps Amplifiers based on integrated circuits |
Hi guys,
I am in the process of gathering the parts for a bridged LM4780. I would like to use two LM4780 per chanell, bridged with a DRV134. I am looking for PCBs for this project and can only find companies in the US (chipamp, audiosector). Would you know any in Europe to save some on shipping and custom taxes ? Thanks for your help, Cheers Patrick |
#2 |
I can't really find any boards (with a decent layout) that are for the LM4780 in bridged mode either-it might be that you have to use an external bridge adapter and connect the in phase and out of phase outputs of this to the two inputs of the LM4780 board.
One thing you must remember is that the lowest impedance speaker you will be able to use with this amp realistically would be an 8 ohm driver (presenting 4 ohms to each half of the amplifier). Even then, you would have to run the power rails at a lower voltage because of the high thermal resistance of the junction to case. You could put as big a heatsink as you want on it but it simply would not be able to transfer the heat from the output transistors (junction) to the case quick enough (to be transferred to the heatsink) and would lead to overheating internally. Another place you could try would be eBay however, the quality from some sellers is very variable and in some cases you might not even get a board at all. Maybe this is a gap that the DIY community could fill? A group collaboration to produce freely available LM4780 board layouts that are well optimised. Just a suggestion. Edit: There is quite a good layout on the National Semiconductor datasheet but this is double sided and would be difficult to make yourself unless you have the equipment. Sending it off for production would also require you to copy the layout onto an appropriate PCB layout program and send it as one of their files. Last edited by jackand08; 5th January 2011 at 05:52 PM. |
#3 |
Here's my old version, been running well as the PC sound system for the past five years. For bridging the sub channel, I just used a balanced line driver IC made up on a bit of perfboard. About half a dozen components, if that.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 | ||
I was planning to go in this direction (bridge/parallel): Build Power Amplifier LM4780 with BPA-200 Amplifier - Electronics Now! schematics, Electronic circuit, PCB or project for Electronic. Quote:
Thanks for your help anyway
#5 | |
Thanks for the design !! Is it running bridge or parallel ? I am looking for parallel. I will then bridge two LM4780 with a DRV134. |
#7 | |
Nothing fancy about the layout, but it works well, and as I said, has been in nearly constant use for five years. I'll have a root around and see if I can find a pic.
#8 | |
Regarding the power supply using a 25VAC transformer will give you around 35V unloaded after rectification and filtering. The power dissipation from the chip's into an 8 ohm load shouldn't exceed their maximum. One more question-is it a BTL (bridge-tied load, basically a bridged) amplifier you want to make or a BPA (bridged parallel amplifier) as the circuit in the link you sent is a BPA circuit. These are both quite different. Just to confirm, bridged amplifiers give you more voltage swing at the expense of higher power dissipation in each chip. On the other hand, parallel amplifiers give you the same output power as one amplifier but more output current capability without exceeding the chip's limits (the current to the load is spread across two or three chips, which dissipate less power individually), allowing you to drive a lower impedance load. A BPA gives you both advantages: higher power output (more voltage swing), but also the ability that a parallel amp gives you to drive lower impedance loads. Last edited by jackand08; 5th January 2011 at 07:01 PM. |
#9 | |
#10 | |
![]() I think I should be carefull with the heat. My heatsinks are not that big ... 30cm*8cm*4cm ...
| LM4780 paralell pcb | sasmit | Chip Amps | 30 | 18th August 2010 01:13 PM |
| yet another LM4780 pcb | zdr | Chip Amps | 7 | 24th September 2008 08:29 PM |
| LM4780 pcb layout and others | BrianGT | Chip Amps | 263 | 12th January 2008 11:26 PM |
| Lm4780 Bridged PCB | Baracus | Chip Amps | 8 | 7th January 2006 12:45 AM |
| Page generated in 0.11604 seconds (84.29% PHP - 15.71% MySQL) with 11 queries |
