Old 5th January 2011, 10:52 AM   #1
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
Default sure 8W vs 25W module.
I bought the 8W Sure module http://www.parts-express.com/pdf/320-310m.pdf . It has the same TPA3123D2 chip as its bigger brother the 25W module http://www.parts-express.com/pdf/320-304m.pdf . Is it OK to power the 8W module with 30V supply to get more power? Sure electronics recommend <16V supply. All electrolytes connected to VDD has 35V rating but I'm not sure about the ceramic caps rating. Should I continue?
Old 5th January 2011, 11:02 AM   #2
Saturnus's Avatar
Not actually a chip amp so this belongs in the class-D forum.
Anyways, the output filter caps are 16V types which would have to be changed.
Old 5th January 2011, 03:04 PM   #3
Ipanema's Avatar
Do you have infos about the ceramic caps rating?
Old 5th January 2011, 03:25 PM   #4
Saturnus's Avatar
Don't know really but check the reference schematics in the back of the pdf you posted. All those that have 16V after them, ie. the output filter caps and decoupling caps, will have to be replaced. The MKP caps can stay. Then you'll have to check those that don't have a marking in the schematic.
Endangered Audio - Gristleizer Module & New Module Line! endangeredaudio Vendor's Bazaar 0 5th March 2010 03:03 PM
The monster 8W reviews neazoi Solid State 2 18th February 2009 07:02 AM
Vishay/Dale 1/8W Precision Metal Film Resistors_ERC-55-200 pinkmouse Swap Meet 1 11th February 2005 11:25 AM
Why can 8W sound as loud as 100W? AudioIsFun Tubes / Valves 19 26th January 2004 03:05 PM
Page generated in 0.05597 seconds (78.58% PHP - 21.42% MySQL) with 10 queries
