| Chip Amps Amplifiers based on integrated circuits |
Hello,
I have bought the LM3886 gainclone kit from ChipAmp.com the PSU board look like this : ![]() the problem is that my transformer is center taped (3 wires) instead of 4 wires. ![]() Is there a way to use this transformer with that PSU board ? and how ? If not, there's some PSU boards on Ebay like this one Amplifier Power Supply Assembled Kit for DIY NEW en vente sur eBay.fr (fin le 08-janv.-11 10:26:00 Paris) that could be suitable ? Regards |
#2 |
I bought the same brian-gt boards. I just used dual secondary trafos for that one.
the peter daniels kit does seem to 'support' CT style trafos. he documents where to make changes (4 diodes instead of 8, etc) on his website. btw, that diagram you show is wrong, isn't it? the 2nd bridge is backwards, it seems. wonder why no one ever fixed that (?)
My Photostream:http://www.flickr.com/photos/linux-works/ |
#3 |
just disregard the ct and run secondery to both ac's.
#4 | |
Linuxworks, the document is from Brian web site, so hope the board are ok.
Will look at Peter web site. Toufu, Quote:
#5 |
no, that's not optimal. that often (according to reports) creates hum and loops.
#6 | |
#7 |
I explained it here: Center tap torroid wiring to peter daniels kit???
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#8 |
Thanks Peter for the link.
the PSU board of Brian LM3886 and yours are quite different, do you think this can apply in my case also ? |
#9 |
The layout and traces, although may look different, are basically the same, so the mod will work with his boards as well.
#10 |
his current boards include room for both the diodes and filter caps. if the filter caps part assumes dual secondaries, I wonder if it really will be straightforward..
I have both of your kits but have not looked at it in detail on brian's since it did not look obvious at first glance. I am curious, though. searches did not turn up any specific howto on the brian boards like it does on yours.
| What happened to Brian Gt? | atala | Pass Labs | 28 | 19th January 2011 06:00 PM |
| 1-bridge PSU for center-tapped transformer: What's the disadvantage? | Spasticteapot | Chip Amps | 4 | 23rd March 2006 10:02 PM |
| Brian GT LM4780 Bridging | juan_caliente | Chip Amps | 15 | 4th September 2005 10:58 AM |
| 15V + - Regulator Board Brian GT Board. | jleaman | Solid State | 16 | 9th March 2005 05:28 AM |
| Page generated in 0.09840 seconds (78.80% PHP - 21.20% MySQL) with 11 queries |
