| Chip Amps Amplifiers based on integrated circuits |
Hi all,
first of all, happy new year to all and your familly ![]() I have bought 2 years ago a gainclone made of LM3886 from China from ebay. Fake chips, bad build quality and partialy broken case during shipping. Here's a Italian test of the same amp : Recensione: DeskTop Star Gainclone by Hlly Electronics After repairing it I have used it during 2 years. Now it's time to get something better, I will only keep transformer and speaker protection unit from previous amp. I have bought PCBs from DIY Chip Amplifier Kits, PCB's, Components and Information. I have bought the Dual Mono Kit, but for now I have only one transformer, so I use only one power supply board. (like stereo version) Haven't tested if everything is ok, but should be. I had a look at the speaker protection board, and there L/R channels have same ground, the previous amp also used common ground (from RCA input to output). The chipamp kit always use separate grounds, so is it problematic if the output of the both amplifier boards are connected together to be able to use the protection unit ? Thanks for your help. Regards ads |
#2 |
If both amplifiers are in the same case, they will share the same ground anyhow.
If the speaker grounds are really connected together at the protection board, you need to make sure not to create a ground loop. In that case you should rather take the protection board ground to the star-point instead of routing the speaker ground through the board.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Thanks Pacificblue for your help.
#4 |
#5 |
My transformer is the same as Recensione: DeskTop Star Gainclone by Hlly Electronics - Pagina 3 it seems that Maurarte has suceeded to revert from 3 wires to 4 wires, but I don't understand Italian.
#6 |
Yes you can use the centre-tapped transformer. You only use one rectifier instead of two.
#7 |
Thanks pacificblue for the picture, will try to modify the board.
#8 | |
| common ground or not? | Mordor | Car Audio | 5 | 7th October 2008 12:08 PM |
| Phono stage common ground hum!! | ungie | Analogue Source | 11 | 2nd January 2008 11:01 PM |
| Common Ground layout on Eagle | -_nando-_ | Everything Else | 18 | 17th December 2007 03:03 PM |
| A common ground between preamp and amp | marthaman | Solid State | 4 | 3rd November 2007 09:00 PM |
| Adcom...common ground amp?? | Heiney9 | Solid State | 59 | 25th October 2005 02:06 PM |
| Page generated in 0.09192 seconds (74.12% PHP - 25.88% MySQL) with 11 queries |
