| Chip Amps Amplifiers based on integrated circuits |
The lowest noise dual JFETop-amp that I can find is the OPA1642 with 5.1 nV/root-Hz of voltage noise. I need the low current noise too (it's 0.6 fA/root-Hz for the aforementioned op amp). Does anyone know of a lower voltage noise dual JFET op amp? I know there are lower noise dual op amps, but all that I've seen have much higher current noise than my application can tolerate. Oh, I'd like one that runs with +/- 15 volt supplies too. Other spec I need is at least 10 MHz GBP. Regards, Ken |
#2 |
where does the noise need to be low - A weighting?, what source/feedback Z?
The lowest noise jfet input is the single AD743/5 if lowest possible 1/f corner frequency isn't important then some CMOS parts may be useful plot from thread new interesting CMOS op-amps |
#3 |
Thanks,
The AD743 has too high input C for my application, otherwise the 2.9 nV/root-Hz is attractive. The high C increases the noise gain of the first stage. My application isn't audio, it's a transimpedance amplifier that's used to amplify a photo diode. I need ultra-low noise for this application. I attached a schematic to this reply. It has a unique topology in that I use two capacitors to multiply the photodiode AC current by a factor of 30, noise-free. I get a total effective transimpedance of 41 MOhm, but only get noise that's equivalent to a 1.34 MOhm resistor. Gain peaking occurs around 1 kHz and the Vn starts to become a problem because the noise gain of the op-amps starts to get large. Current noise needs to be low too, so a JFET (or CMOS) op-amp is the only choice. Ken |
#4 |
I looked at a few CMOS op-amps from the thread you sent me, however they operate from low supply voltages. I need a dual that operates from +/-15V. Also, my circuit's bandwidth is 100 Hz to 10 KHz. Regards, Ken |
#5 |
you might seach photodiode transimpedance bootstrapping
I remember seeing descrete jfet Q in front of op amp photodiode transimpedance amps I need to spend some time to see if this paper's bjt cascode/bootstrap is a good idea http://www.electrooptical.net/www/fr.../frontends.pdf also you shouldn't let Vsupply prevent you from using the best op amps for the applicaiton - higher speed processes are lower V, you can make a compostie op amp circuit with a 2nd hgier V output chip if you need the Vout Last edited by jcx; 31st December 2010 at 11:32 PM. |
#6 |
JFET bootstrap is a good idea, I thought of that too, may have to go that way if I can't find a dual with Vn < 3 nV/root-Hz. Real estate is kind of a problem since the PCB is has to be about the size of a two pieces of Dentyne gum.
#7 | |
Previously: Kuei Yang Wang
This should manage < 1nV |/Hz J-fet Dual. Only needs the dual J-Fet and 3 SMD resistors added per op-amp, survivable even in a confined space, SMD versions of Op-Amp and J-Fets are available. Ciao T Last edited by ThorstenL; 1st January 2011 at 07:01 AM. |
#8 |
could one assemble a pair of lsk389 and a pair of 5534, all smd size, onto a converter board that fits an 8 pin dil - dual opamp socket?
The 389 would feed into pins 5&8 of the 5534, thus removing the BJT input pair. Check which pins go to the BJT collectors !
regards Andrew T. |
#9 |
Thanks Andrew,
Collectors of the NE5534 come out to pins 1 and 8. Thanks everyone for the suggestions. Ken |
| Low noise dual JFET pair | rtarbell | Parts | 4 | 17th March 2006 10:11 PM |
| Low voltage noise dual OP | Holger Barske | Parts | 7 | 24th May 2004 06:57 AM |
| Ultra low noise JFET voltage regulator | Kochkurov Maxim | Digital Source | 6 | 25th January 2004 11:33 AM |
| Ultra low noise dual jfet | Pjotr | Parts | 7 | 6th December 2003 02:10 PM |
| Page generated in 0.71310 seconds (12.45% PHP - 87.55% MySQL) with 11 queries |
