Old 29th December 2010, 10:05 PM   #1
Default Rotel RA9708X Pot
I have an old Rotel RA9708X amplifier with a dual volume pot, and one channel is dying on me.
The pot is marked VR501 on the print card, and 50KAX2 on itself.
Can anyone recomend a replacentpart for it, and where to buy it online?
Any help would be much apriciated!!
-Kvikkas
Old 1st January 2011, 12:56 AM   #2
Trebla is offline Trebla  United Kingdom
Maybe better to ask the question in the Solid State or parts section of the forum...
Anyway, 50KAX2 suggests an Alps pot, so just replace with a new 50k Alps pot and use wire links to connect to the circuit board.
If you are sure that the pot is faulty.
Old 1st January 2011, 02:14 AM   #3
ashok's Avatar
Squirt some isopropyl alcohol into it and turn it several times. It might clear your problem.
AM
Old 1st January 2011, 02:46 PM   #4
if you can't find a replacement or make one fit, if it was me I'd bypass it (set it at max with direct wires) and use an external attenuator for varying volume.
then, the sky's the limit. passive, active, cheap, expensive, you name it.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 2nd January 2011, 11:10 AM   #5
jaycee is offline jaycee  United Kingdom
it's a dual 50K logarithmic taper potentiometer. The pinout spacing also looks quite standard. If you cant get dual 50K, then dual 47K should work pretty well.
Where to buy - would depend on where you live!
Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player Staykov Digital Source 5 16th May 2012 12:24 AM
Rotel RC-850 Pre Amp + Rotel RB-870BX bleachershane Analog Line Level 4 9th February 2009 11:20 AM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Effect of using 50k pot instead of 100k pot in tube preamp? KT Tubes / Valves 5 17th February 2006 09:56 PM
Converting a DACT series pot to a shunt pot Dr.H Chip Amps 9 2nd December 2004 01:55 PM
Page generated in 0.07654 seconds (75.22% PHP - 24.78% MySQL) with 11 queries
