Old 25th December 2010, 03:29 AM   #1
Default Audio Amplifier TDA2030A
Can you tell me this circuitry of Audio Amp TDA2030A whether this is correct or not ?
Thank you !
Old 26th December 2010, 03:12 PM   #2
Here it is the PCB of TDA2030A ! Just see it,test it and comments about its usefulness !
Old 26th December 2010, 03:49 PM   #3
boyofwax's Avatar
The diagram looks OK, have not checked the pcb. There are many configurations possible for this power opamp. I suggest you study the datasheet on this one. The diagram as shown above needs a dual supply.
Old 26th December 2010, 09:55 PM   #4
It looks as if there are components overlapping (flyback diodes and capacitors).
The input DC blocking cap is missing on the board.
Add 100 nF decoupling caps as per datasheet next to the TDA's supply pins.
Dedicated terminals or solder pads for the power supply will make things easier. If you connect the supply wires to components, there is the risk of inadvertently disconnecting the component while connecting the wire.
Avoid right-angled traces. Use curves or 45° angles.
You should also pool signal ground and power ground on the board so that you only need two return wires to the star point instead of six.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 27th December 2010, 03:26 AM   #5
Thank you for your inputs !
I am following the schematic from a audio amp book as I provided a snapshot in my first post. I am not following the datasheet of this amp. Why I need a dual supply ?
Old 27th December 2010, 03:29 AM   #6
Thank you for your reply !
Can you explain this "You should also pool signal ground and power ground on the board so that you only need two return wires to the star point instead of six" ?
TDA2030A Power Amplifier Matthewong Chip Amps 32 23rd December 2010 05:44 PM
Extra Gain with tda2030a pra3718 Chip Amps 0 23rd December 2009 08:49 AM
tda2030a Heatsink hernanstafe Chip Amps 10 17th December 2007 12:47 PM
TDA2030A Power Amplifier ali_moinuddin Vendor's Bazaar 1 24th September 2007 09:56 AM
Page generated in 0.07617 seconds (76.27% PHP - 23.73% MySQL) with 11 queries
