TDA2050 better than LM3875 and transformer VA rating
Old 18th July 2003, 01:49 PM   #1
Dr.H is offline Dr.H
Default TDA2050 better than LM3875 and transformer VA rating
Hi All,
I seem to recall reading somewhere that TDA2050 gave a more refined sound than LM3875 in gainclone implementations. Any views on this?
Also, I have 2x300 VA transforners (20V secondary) which I intend using for my LM3875 implementation. Is it corect to say that teh higher the VA rating of the transformer the better? I have seen that others are typically using only 120-225 VA transformers.
Ryan
Old 18th July 2003, 02:30 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
TDA2050 better than LM3875 and transformer VA rating Send a message via AIM to Peter Daniel
I fixed your mistake. I tried TDA7294 once and it wasn't as refined as LM chip.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th July 2003, 02:46 PM   #3
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Ryan
Within certain limits higher VA rating may be beneficial for the sound. I have, however, tried a very large (1000VA) transformer once and the sound was remarkably flat and unexciting. How much you can blame on the core size, wire quality, core type etc is not very clear as these experiments tend to get very expensive. I am still determined to try high quality, very thin J-laminations with distributed gap which a local winder can get. Won't be cheap
cheers
peter
Old 18th July 2003, 03:20 PM   #4
carlosfm is offline carlosfm  Portugal
Banned
Default Re: TDA2050 better than LM3875 and transformer VA rating
Originally posted by Dr.H
Hi All,
Ryan
160~200 VA is good for one channel.
I use one single 384VA toroid for the two channels.
Your 20V, 300VA transformer will do fine for two channels.
Old 18th July 2003, 04:58 PM   #5
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Hi All,
I've tried both, and I can tell you: Forget the TDA2050!
It simply stinks! Giving a very coloured sound, and is hard to get stable. Definately not suited for a minimal GC.
Mads K
Old 18th July 2003, 06:59 PM   #6
Bricolo is offline Bricolo  France
Bricolo's Avatar
has anyone else tested the TDA7294?
Old 18th July 2003, 07:06 PM   #7
millwood is offline millwood  United States
Account Disabled
that's the one that uses mosfet for output. It was the rage in the far east diy circle (last november). Said to be excellent but I never tried it myself.
Old 18th July 2003, 07:30 PM   #8
Bricolo's Avatar
Yes, this one uses fets
That's the chip I use in my gainclone.
Peter sayd that he didn't like it, but I didn't compare mine to another chip (LM3875 not available here, national refuses to send me samples, and OPAs are also not available)
Old 18th July 2003, 07:47 PM   #9
Mad_K's Avatar
-So TI will not send you samples?
Mads K
Old 18th July 2003, 07:55 PM   #10
Bricolo's Avatar
haven't tryed
TDA2050 better than LM3875 and transformer VA ratingHide this!Advertise here!
A TDA2050 Victory but trouble with transformer Paswa Chip Amps 12 29th October 2007 04:20 PM
Transformer VA rating?? RyanW Power Supplies 6 11th November 2006 10:23 PM
Transformer VA Rating vs. Current Rating JhonDoe Chip Amps 45 5th June 2004 01:11 AM
Spice models LM3875 and TDA2050 Jarno Solid State 5 3rd February 2003 11:06 PM
Copyright ©1999-2017 diyAudio
