TDA2050 better than LM3875 and transformer VA rating
Old 19th July 2003, 06:44 AM   #11
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Then you're missin' out big-time methinks...
Mads K
Old 19th July 2003, 05:28 PM   #12
Alex S is offline Alex S  Singapore
The TDA2050 does sound much better than the LMs but needs battery or regulated supply because of it's low PSRR and hence should not be implemented with a minimal style power supply a la Gaincard.
Other TDA chips e.g. TDA7294 have more complex circuitry (such as mute) and probably may not sound as good.
Old 19th July 2003, 08:33 PM   #13
Mad_K's Avatar
I used 2*15000uF Rifa PEH200 caps +100uF+100nF local decoupling....... 2*15V 200VA Toroid with my TDA2050. Circuit as in the datasheet (including Zobel).
Mads K
Old 19th July 2003, 08:43 PM   #14
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
[QUOTE]Originally posted by Alex S
I'm glad you said that. I was begining to doubt my own experience. someone asked me to make an amp that would run from a 12V battery and because of the low voltage I chose tda2050. two per channel balance working. everyone that heard that amp really liked the sound and it was that, and thorsten, that got me back into the chip amp scene.
cheers
mike
TDA2050 better than LM3875 and transformer VA ratingHide this!Advertise here!
A TDA2050 Victory but trouble with transformer Paswa Chip Amps 12 29th October 2007 04:20 PM
Transformer VA rating?? RyanW Power Supplies 6 11th November 2006 10:23 PM
Transformer VA Rating vs. Current Rating JhonDoe Chip Amps 45 5th June 2004 01:11 AM
Spice models LM3875 and TDA2050 Jarno Solid State 5 3rd February 2003 11:06 PM
Copyright ©1999-2017 diyAudio
