| Chip Amps Amplifiers based on integrated circuits |
I've recently finished my Kit281s and I bought a Kenwood 4090 which is rated at 120w x 2 @ 6ohms stereo and 80 x 5 @ 6 ohms in surround mode. The stereo mode sounds absolutely fantastic... deep bass... lots of depth and nice highs.... but when it goes into surround mode the speakers sound flat.... I'm guessing the 80watts isn't enough power. Where would be a good place to start and a good amp to build for a newbie with a limited budget? Just need it to be 2 channel to compensate for the drop in power when the receiver isn't in stereo mode.
Thanks, Rob |
#2 |
A chip amp would be easy to build but you will need to know how to connect it up to the control section of your Kenwood.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
I've got those speakers also and I'm willing to bet a chip amp won't have enough power. They are difficult loads and inefficient. A paralleled Gainclone may work.
I'm using this amplifier, but it might not be a good idea for someone with little experience (myself included) to build: http://www.aussieamplifiers.com/downloads/symamp.pdf |
#4 | |
I guess I am not exactly sure what you mean... I have 5.1 channel RCA pre-amp outputs suited for an external amplifier. These wouldn't work?? rob. |
#5 | |
i'll try over in the solid state board i guess.... are yours the TL version and are you satisfied with them? I love mine, but have not heard many speakers above about $2k. What I have heard around $2k though.... mine blow them away. rob. |
#6 | |
My only comments then would be to make a non-inverted chip amp but I would have to bow to Kilentra here who obviously has expereinece of driving your type of speakers.
#7 |
Not so much, I've had the 281s for almost 2 years now, and I tried three different amplifiers: an Audiosource integrated supposedly better in quality than a receiver, the Pass Zen V4, and Holton's symmetrical amp. (I will be bi-amping with the latter two amps.)
I have the vented/overdamped version and they're wonderful although I have no experience comparing them to other speakers, I understand and sort of wish to improve on their problems. But that's OK, since I will never "buy" speakers again. The Audiosource amp (100 watts or so) could be pretty impressive, but it would run out of steam too easily - and the sound wasn't quite as clear even at lower volumes. I would expect similar problems with a receiver, though you might not notice them until you put in a stronger amp and they're gone. |
| need power supply advice for future power amp project. | boricuaso | Chip Amps | 13 | 6th February 2008 02:24 PM |
| First Timer needs help | mgalvez | Tubes / Valves | 24 | 17th October 2007 10:34 PM |
| Need help with PIC timer. | Tolik | Parts | 9 | 9th May 2007 10:02 PM |
| Adire Shiva 12" subwoofer project plans | sirius98 | Subwoofers | 13 | 9th November 2004 10:51 AM |
| Adire EBS sub project | mightyjimbo | Subwoofers | 1 | 5th March 2004 03:57 AM |
