Old 8th December 2010, 12:53 PM   #1
richloh is offline richloh  Singapore
Default Help On Op Amp Options
I am trying to improve the sound quality from the Alpine TUA-T100DAB tuner as this is the only non-digital source into my H900 processor and started trying out different op amp to substitute the NJM4580s seen. With AD8599 replacing all the NJM4580s, I get good bass but sound quality became aggressive and harsh especially for the vocal ... not sure if op amp needs burn-in period but it is not oscillating as scoped.
I checked the service manual again per enclosed and note that there are LPF stage, 2 buffer stages and this ISO amp which I am still trying to find out learnt about them.
Can anyone help to advise on the following:
- why is there 2 buffer stages as I did not see 2 buffer stage in the block diagram ?
- ISO amp would not affect sound quality and hence can be left alone ?
- any recommendation for the Op Amp replaced for the LPF stage IC5, Buffer Stage IC8 and Buffer Stage IC307 (or even ISO amp IC308) ??
Please also advise what are the consideration for choosing "better" op amps for the mentioned LPF stage, 2 buffer stages and ISO amp, if at all possible.
Thanks in advance.
Old 8th December 2010, 01:05 PM   #2
request this be moved to Analogue Source or to Solid State.
This reads like unsuitable opamp replacement.
I think you need an oscilloscope to monitor what is happening to the power supply pins and the outputs for ALL the new opamps that have been substituted.
regards Andrew T.
Old 8th December 2010, 01:36 PM   #3
Missed the enclosed schematic and block diagram
Old 8th December 2010, 01:41 PM   #4
Hi Andrew,
Noted and with apology for wrong posting section. Already posted at Solid State as advised.
Richard
Amp options for the Betsy's keantoken Wild Burro Audio 7 1st September 2010 05:04 AM
Bass Amp options mlanier911 Instruments and Amps 4 12th January 2007 01:58 PM
PP2A3 amp options arnoldc Tubes / Valves 7 15th June 2004 04:43 AM
Options of Volume & transformer for group buy GC? JazzzSpazzz Chip Amps 0 9th March 2004 07:36 PM
Any Bi-Amp options? chris ma Everything Else 3 10th May 2002 10:02 PM
Page generated in 0.07239 seconds (70.24% PHP - 29.76% MySQL) with 11 queries
