Old 23rd November 2010, 05:53 PM   #1
Atilla is offline Atilla  Norway
Soldering Gun Fanatic
Default Low-pass for Active woofer Gainclone
Just a quick question here. What if I wanted to make an active woofer, using a pretty standard LM3886 and a simple low-pass. Can't I just increase the size of the cap between the positive and negative input, so I make a low-pass filter like that? Say, between 0.05 and 0.005uF, depending on what I'm doing? And make it a good polyprop cap, while at it.
Old 23rd November 2010, 06:01 PM   #2
Did it Himself
richie00boy's Avatar
Not that cap, that one is used to reject RF hash. You are best off putting an active filter before the amp. You can use a passive filter, but their response is too droopy I feel.
The worst way would be to add a cap in parallel with the feedback resistor. In non-inverting mode you would still get treble bleedthrough as the lowest gain you can have is 1 and the roll-off is just 6dB/octave which is pretty poor. Also the chip is probably not stable at unity gain.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 23rd November 2010, 06:14 PM   #3
If I put a filter before the amp, I'd make a good, active filter. But really - I couldn't think of any side-effect of increasing the inputs cap to the point where it'd attenuate enough to get down in the audio band. So I'm looking to find one, so I can focus on the active low-pass then
I wouldn't filter an LM3886 trough the feedback no. IIRC, it's far from unity-gain stable. Thanks for reminding me though, considering what I'm asking, I shouldn't be forgetting anything about it.
Old 23rd November 2010, 10:12 PM   #4
frugal-phile(tm)
planet10's Avatar
Can you post the schema you are using?
I can't recall seeing a shunt cap on a gain clone.
A chipamp is just a high powered opamp, so it can be configured as a 2nd order LP (or HP) filter (or even fudged into a 3rd order).
Body
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd November 2010, 11:06 PM   #5
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
True to some degree only - chip amps are not unity gain stable without some fudging networks around them - the K value in your diagram is unity for a typical Sallen-Key configuration.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 24th November 2010, 04:19 AM   #6
sangram is offline sangram  India
I use a 6dB network in front of the chipamp, and another in front of the preamp (if present/necessary). Works well enough - if you need steeper slopes, active filtering is the way to go.
High pass is significantly easier, I just use a small feedback capcitor (Ci) to provide additional 6dB rolloff, plus the 6dB in front.
The one time I messed with the series feedback path I had severe issues with howling feedback, so I didn't pursue that road (STK chip and speakers both survived the ordeal).
The cap between the inputs is also a feedback path, IINM. I'd be interested in the results of this increase, it does seem like a good place to provide rolloff but never tried it myself.
Old 24th November 2010, 11:19 AM   #7
Well, I'll give it a shot and I'll see how it goes. It would be nice to measure freq. response with something though, so I can confirm how it works.
I'm talking about Cs in a configuration like this:
That's not the schematic I'm doing, but it'll do as an example. Just bump Cs to a suitable value for my woofer?
Old 24th November 2010, 12:19 PM   #8
Did it Himself
You would be better putting a cap from the non-inverting input to ground, in conjunction with the 330R it will form a traditional low-pass filter.
Old 24th November 2010, 04:11 PM   #9
Well, that is a fair point, I wouldn't need a bigger cap for that.. Oh well
I'll either install whatever is easier to fit on the board I've got, or I'll place an active filter before it.
Thanks!
Old 24th November 2010, 05:44 PM   #10
Did it Himself
Do the active filter, 6dB/octave is rubbish on a sub.
Ultimate Active Low Pass Filter toshiba_nz Analog Line Level 0 26th May 2010 07:25 AM
Low Pass Filter For Sub-Woofer livenicely Chip Amps 1 1st December 2009 06:35 PM
Tube active low pass crossover Diy martin Full Range 2 2nd November 2006 04:48 PM
Looking for an active crossover design (low pass only)? Graemedench Solid State 5 28th August 2004 12:25 PM
Gainclone Low Pass Filter Matttcattt Chip Amps 25 1st August 2003 11:46 PM
Page generated in 0.09417 seconds (86.50% PHP - 13.50% MySQL) with 11 queries
