| Chip Amps Amplifiers based on integrated circuits |
Hi, I have an AKG C411L condenser contact mic,but without the power pack.So now I've built this simple buffer to power & boost the signal as well. When I connected the C411L to it,although the mic is working,the circuit is "motorboating .The buffer works otherwise just fine with other back electret mics like Panasonic WM61 etc.I have no idea why this mic is behaving this way! Buying a power pack is out of the question,as I think it is unreasonably expensive! The buffer is running on +/-12v dc , proper psu & the load resistor feeding the mic is 15k As you will notice,in the original wiring, both pins 2 & 3 are tied to the mic "hot"! wire. This is my modified wiring Pin 1 screen Pin 2 blue to buffer input Pin 3 red to the 15k supply resistor. Can anyone please tell me what I've done wrong here? Thanks. Last edited by teleman; 11th November 2010 at 12:41 AM. |
#2 |
hello.
i am no mic expert.but i saw a few older versions of akg headsets.the input configuration was: instead of 15k there was 8,2k..........perhaps you will use 10k - similar to the attached schematic. 4,7k left out,none. 8,2k behind the input cap..........here 10k,not far away. i guess the motorboating will not stop,but perhaps try it out. greetings |
#3 |
Hi mjf,
Good to hear from you again! I will of course try your suggestion in the morning & will report back.What puzzles me is that the recommended input impedance value for this C411 mic is > 1k ohm! So do you think making the buffer to an inverting input instead will be any good? Cheers |
| Condenser microphone capsule for AKG-NEUMANN | stevenHK | Vendor's Bazaar | 3 | 20th August 2010 09:06 PM |
| phantom power for condenser mic | patknk939 | Everything Else | 5 | 21st September 2008 07:07 PM |
| 'Tube' preamp bad for measurement mic? also Apex mic question | morbo | Multi-Way | 10 | 23rd March 2005 10:19 AM |
| AKG k-1000 re-wiring | rstek | Analogue Source | 0 | 4th October 2003 03:58 PM |
| AKG 340 | johnp | Solid State | 1 | 25th February 2001 12:03 AM |
| Page generated in 0.08130 seconds (76.72% PHP - 23.28% MySQL) with 11 queries |
