Old 9th November 2010, 02:03 PM   #11
OK pin no.3 and pin no. ? should be connect with 4.7 ohm resistance. input ground is pin no. ? and can i connect pin no.4 with 470uf 16v
Old 9th November 2010, 02:05 PM   #12
and my amp is just on for 10 sec than osilation for 5 sec than mute. I am using the datasheet application as it is.
Old 9th November 2010, 02:52 PM   #13
LAJ is offline LAJ  United States
Default The important thing is...
to have a hefty power supply. 12Volts at 5 Amps according to the spec sheet. I've got one from a BA745 I found in the someone's trash but I haven't done anything with it. But I think I will build it as a 4 channel amp. And its a good idea to have a hefty heatsink as well.
Old 9th November 2010, 05:32 PM   #14
Currently i am using 12 volt at 300mA just for testing it and heatsink is not attached. I am just turning on it. no input signal provided just 4 ohm 4 inch speaker connected.
Old 9th November 2010, 05:43 PM   #15
Do you still have 12V after you turn it on? If so your oscillation may be due to insufficient power supply bypass. I'd use at least 1 amp even just for testing (with no signal input.)
Old 9th November 2010, 05:47 PM   #16
i also tested it on a 140A Lead Acid Battery. I have removed 100nf cap on power supply. because the ossilation was still there with that cap so i removed it
Old 10th November 2010, 12:15 PM   #17
kroto is offline kroto  Indonesia
kroto's Avatar
Send a message via Yahoo to kroto
I mean pin #3 is the signal(input) gnd in the chip, while the input Gnd is the Gnd where your signal came in (like from input connector which is isolated from the chasis).
you don't have to connect signal Gnd and main(power) Gnd via 4r7. but those resistor will help (a little bit) to give the signal line cleaner grounding.
yes you can use a 16V rating cap for pin #4, its only 1/2 the supply voltage.
sorry for my bad English
_@ö
sue
Old 10th November 2010, 12:20 PM   #18
kroto's Avatar
do you mean "then" not "than"?
it could be from your PCb layout. maybe your input line way too close to the output line.
_@ö
sue
Old 10th November 2010, 01:01 PM   #19
I am using polyster capacitor for decoupling. Should i use Ceramic?
Old 10th November 2010, 02:34 PM   #20
kroto's Avatar
mine use polyester too. try 220nF.
try ceramics too.
_@ö
sue
TDA1554Q Bridge-Parallel? kroto Chip Amps 6 28th December 2011 01:28 AM
TDA1554Q output pins (+), (-) pra3718 Chip Amps 1 28th January 2009 10:52 AM
TDA1554Q Questions.... DoomPixie Chip Amps 1 29th May 2006 11:27 AM
TDA1554Q Features Wilson2004 Chip Amps 8 15th July 2004 06:28 PM
TDA1554Q and LM1036 question Wilson2004 Solid State 4 13th July 2004 01:56 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
