new project - chip amp??
Old 13th July 2003, 06:00 PM   #1
yuval is offline yuval
Default new project - chip amp??
hi all,
I was suggested to check on chip amps so here I am.
I'm looking for an amp that will be able to drive my Sonus Faber - concerto home in a medium sized room.
Currently, I'm using valve amp - WAD kit6550 40Wpp but it's getting too hot for some days at the summer here ...
Chip Amp is my solution ?
thanks,
Yuval
Old 13th July 2003, 09:29 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Well, there is no guarantee that a chip amp will work with your Sonus Faber Concertos but no real reason why they shouldn't.
What sort of sensitivity are the Concertos?
I was joking with somebody only today, that a Gainclone is a better option than a valve amp in this hot weather.
If you are new to chip amps, then you will probably be best to stick with the minimised inverted design using the LM3875. Why? Because that's what most people choose to build and there is a lot of advice for that version.
If you want to get off to a good start, try THIS
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 13th July 2003, 09:47 PM   #3
Thanks, I'v been looking around and already put this link and some other in my favorites, but I still have a lot to catch up.
The concertos are 88db / 6ohm nominal impedance ...
cheers,
Yuval
Old 14th July 2003, 01:47 AM   #4
millwood is offline millwood  United States
Account Disabled
chps amps aren't the best in the world to drive low impedence and not so sensitive speakers. my guess i sthat it is likely to work but it may not be optimal.
new project - chip amp??Hide this!Advertise here!
My First Chip amp project - TA7270P Bow Chip Amps 3 21st October 2008 12:51 PM
Which Chip for first DIY project? systemerror909 Chip Amps 3 9th January 2006 05:32 AM
Suggestions for a chip amp Kit or Project? santiu Chip Amps 5 12th November 2005 05:06 PM
A new chip amp project JOE DIRTŪ Chip Amps 11 17th June 2003 02:56 PM
Copyright ©1999-2017 diyAudio
