And now, the Regulator-Chip JLH Amp.
Old 26th October 2010, 11:33 AM   #1
Elvee is offline Elvee  Belgium
Elvee's Avatar
Lightbulb And now, the Regulator-Chip JLH Amp.
After the Regulator Chip Amp and the Chtringlunator, it is time to translate the JLH topology into voltage regulators (I hope JLH won't be turning in his grave).
The task is pretty straightforward, and the results are excellent.
And since the circuit operates in class A, it doesn't have slew-rate issues.
In practice, R2 and R9 can be halved: the spice model I have for the LM317 reaches its current limit at only 850mA, about half the actual device. This will make the amplifier able to drive a 4 ohm load.
Pics will follow.
Old 26th October 2010, 05:01 PM   #2
Elvee's Avatar
Here it is:
Old 26th October 2010, 06:18 PM   #3
pacificblue is offline pacificblue  Germany
You devise lots of funny amps. Will you ever tell us how they sound?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 27th October 2010, 02:23 PM   #4
Elvee's Avatar
A small rectification: the circuit shown in the pictures above is slightly modified.
Here is the actual schematic.
I don't think so. You'll have to try for yourself. It won't cost you a fortune though
Old 28th October 2010, 08:07 AM   #5
ampimp is offline ampimp  United Kingdom
Banned
Hi Elvee
Very interesting
How about a chip amp regulator ??? To feed your regulator chip amp?
Regards Ian
Old 28th October 2010, 02:04 PM   #6
Elvee's Avatar
Originally Posted by ampimp View Post
Hi Elvee
Very interesting
Regards Ian
Why not, a chip amp would make a nice, 4-quadrant PSU.
But the PSU would then be more expensive than the amplifier it feeds.
Old 29th October 2010, 09:01 AM   #7
Banned
I find the psu is offen the most expensive anyway so im guessing a four quadrant psu would cost four times as much.or is that 16???? Im not even sure what a four quadrant psu is . would it be four times as much fun to design. if so it would be worth it .
Ian
Old 29th October 2010, 09:26 AM   #8
Banned
Ian
Old 29th October 2010, 04:27 PM   #9
Elvee's Avatar
You are probably including the transformer and filter caps, which are needed anyway.
It is a supply capable not only of sourcing current, but also sinking it, and for both polarities.
High end lab supplies have that feature, they can serve not only as conventional PSUs (with better dynamic performances), but also as electronic loads.
Old 29th October 2010, 04:44 PM   #10
And now, the Regulator-Chip JLH Amp.Hide this!Advertise here!
What happens when you cross a Tringlotron with a Regulator-Chip Amplifier? Elvee Chip Amps 17 17th September 2011 07:34 AM
Just for fun: The Regulator-Chip amplifier Elvee Chip Amps 4 21st October 2010 02:19 PM
Placing regulator chip close to amplifier terranigma Power Supplies 4 8th June 2010 08:47 AM
Help needed to identify a boost regulator chip. ashok Power Supplies 11 15th September 2009 03:53 AM
Copyright ©1999-2017 diyAudio
