After the
Regulator Chip Amp and the
Chtringlunator, it is time to translate the JLH topology into voltage regulators (I hope JLH won't be turning in his grave).
The task is pretty straightforward, and the results are excellent.
And since the circuit operates in class A, it doesn't have slew-rate issues.
In practice, R2 and R9 can be halved: the spice model I have for the LM317 reaches its current limit at only 850mA, about half the actual device. This will make the amplifier able to drive a 4 ohm load.
Pics will follow.
