Old 24th October 2010, 10:51 AM   #1
Default How to put a headphone jack in your circuit ?
Hello again, everyone . I was wondering how you would put a headphone jack output in your audio circuit since it would be a very useful thing for me. Can you guys help me ? Here's the schematic:
Old 25th October 2010, 06:07 AM   #2
ratza is offline ratza  Romania
ratza's Avatar
You can't. The outputs are bridged.
Any solution is a compromise.
Old 25th October 2010, 01:59 PM   #3
macboy is offline macboy  Canada
You can connect headphones to a single end of the speaker outputs rather than using the bridged output. This is necessary since the headphones require a common ground.
Try the following. I'd start with the Resistors at about 120 ohm, and the Capacitors of 100 uF. Tweak the values if you want. Use polarized capacitors since they will have DC across them. Be careful of the volume of the output, you don't want to blow your headphones - or your ears. You can increase the R to reduce volume, but that will also affect the sound. Headphones are (supposed to be) designed to have a 120 ohm resistance in series (see IEC 61938).
Old 25th October 2010, 08:25 PM   #4
Thank you SO much ! I love you man
Old 2nd November 2010, 02:23 PM   #5
Oh, and by the way, should ground on the headphone jack be connected to signal ground or power ground ?
Old 3rd November 2010, 12:26 PM   #6
I only see one ground in the schematic above; nonetheless, connect it to the power ground (at/near the 2200 uF capacitor ground leg).
Need help with headphone jack DJelly Headphone Systems 3 22nd July 2009 05:39 PM
headphone bypass jack nukaidee Headphone Systems 9 3rd February 2009 07:38 PM
breadboard headphone jack mbates14 Headphone Systems 2 9th November 2008 03:11 PM
which is which in a headphone jack? jarthel Headphone Systems 7 15th April 2007 08:52 AM
adding a headphone jack Bama Slamma Headphone Systems 1 13th March 2007 01:36 PM
Page generated in 0.08867 seconds (75.16% PHP - 24.84% MySQL) with 11 queries
