| Chip Amps Amplifiers based on integrated circuits |
Hello everyone. I'm very new to diy audio and making amps and such, but i've decided to give it a go and try building a 2x22W stereo amp with the TDA1554 Chip. Now i have all the parts needed but i don't have a PSU yet. Since i don't have any money to buy a new one, i was thinking of using an old AC-AC converter i have. It converts 220VAC to 12VAC 4.2 amps. The circuit however, needs DC current and not AC and it needs 5 amps to operate on full power. Would this AC-AC converter i have work ? Is the current enough ? Also, how would i convert the 12VAC 4.2 amps to DC current ?
#2 |
i don't think is a good idea to use that AC-AC converter, for two reason:
1) 4.2 A are too under the requirement of your circuit 2) the AC/DC converter (the rectifier module) introduces other losses, so you would have few than 4.2 A. I think in this forum, even if i'm new, there are alot of AC/DC rectifier schemes to work on, but if you need more info i can find some reference on it. |
#3 |
By AC-AC converter do you mean a transformer? In that case you need a rectifier bridge or 4 diodes and a big smoothing cap with 2200 µF or more. Small snubber caps across the rectifier are recommendable on top of that.
12 V AC leads to ~16-17 V DC ± regulation and mains tolerances, so you should consider to use a transformer with a lower secondary voltage. You must also take into account that there are no 220 V mains anymore and your 220 V transformer connected to a 230 V grid will give you a higher secondary voltage of 12,5 V to begin with, resulting in ~17-18 V DC, again ± regulation and mains tolerances. While such a car radio amplifier is quite rugged, overvoltage could shorten its life expectancy, if you live in a region with healthy mains voltage.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#4 | |
#5 |
Banned
Hi
It would be a very good idea to do a little reading about eletronics basics before you attemp to build an amplifier. you are about to play with mains voltages . im not sure if i can post a link but i will try. Tutorials, Electronics made EASY, Williamson Labs this site is very good and is easy to understand . I hope this will help you in your quest. Regards Ian |
#6 |
The diodes should be able to pass the maximum current which is 16 A for the TDA1554. The voltage rating should be bigger than 4,5 times Ueff, i. e. more than 60 V for you transformer.
If you don't know how a rectifier is made from 4 diodes, you'd rather use a bridge rectifier. They are usually cheaper and you don't have to worry much about the connection.
#7 | |
#8 |
Ok, yesterday i made a rectifier circuit from 4 diodes that i had laying around. The rectifier is properly converting the AC to DC (i tested it with an LED and a resistor). The only thing that i don't know is how many amps of current it gives off now since my shitty multimeter doesn't measure current. But thanks for the replies everyone.
#9 |
The current is determined by the load, not the rectifier. Look up the datasheet for the diodes you used and it will tell you the maximum voltage and current rating of those diodes.
#10 | |
| tda1554 amp attempt... | mikee12345 | Chip Amps | 20 | 27th January 2010 05:27 PM |
| Where can i get a TDA1554 | Ridin '24'z | Vendor's Bazaar | 1 | 20th February 2007 04:43 PM |
| little or no amplification on tda1554 | kasemodz | Chip Amps | 10 | 26th May 2006 03:37 PM |
| my 1st diy tinny TDA1554 amp! help me.. | deepanger | Solid State | 6 | 22nd November 2002 01:24 PM |
| Page generated in 0.11538 seconds (82.49% PHP - 17.51% MySQL) with 11 queries |
