For those who have hum with theyr gainclone (loud or not)
Old 11th July 2003, 09:45 AM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default For those who have hum with theyr gainclone (loud or not)
Hi all,
I noticed a strange thing with my gainclone.
Both channels have a slight hum, use the same PS (with a velleman 18V 225VA toriod, dual bridge, and 2000F per rail)
Whith no input, I can hear the hum.
The strange thing (tell me if you have noticed the same thing) is that when I manually move (push on) one channel's woofer, the other side's hum is "modulated" by the 1st channel's woofer motion.
Is this normal?
thanks
Alex
Old 11th July 2003, 11:18 AM   #2
UrSv is offline UrSv  Sweden
UrSv's Avatar
A GC should be dead quiet so no that is not normal.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 11th July 2003, 11:37 AM   #3
Bricolo's Avatar
My gainclone has no case, so this can explain the hum (I'm working on the case since yesterday. I started assembling all the aluminium plates)
But I know I'm not the only one with hum, so my question was dedicated to the other people with hum
Old 11th July 2003, 12:13 PM   #4
lieven is offline lieven
lieven's Avatar
floating ground..... check ground connections between supply area and chip.
Maybe wrong placed resistor on ground connection...
Check zobel
my 2 cents.
Old 11th July 2003, 02:43 PM   #5
Bricolo's Avatar
I do'nt want to talk about my hum problem, it'll be certainly fixed when I'll put the amp in it's metal case
I wanted to know if the other people that have hum ( even if it's very low) have the same thing as I have, when they manually move a woofer
Old 16th July 2003, 09:11 AM   #6
Paulr is offline Paulr  United Kingdom
Default The joys of electromagnetics
Hi Bricolo,
By moving your woofer you are inadvertantly causing a voltage to flow backwards towards the amp/ground. A speaker is a magnet & a coil of wire, move the coil back & forth over the magnet & you cause electron flow just like in the science experiments in school.
This is where I come unstuck: does the backward voltage go via the earth & change the relative voltage on the (-) pole on the other speaker? or does it affect the chip itself to cause the modulation?
Heres hoping I've helped more than I've opened new lines of questions.
Cheers
Paul
Old 16th July 2003, 07:57 PM   #7
rocktboy is offline rocktboy  United States
i tried pushing my woofers on one channel and the other channel isn't affected by it.
my hum/hiss actually become less as i turn up the volume
either way the hum/hiss can be heard only when you stick your ears right next to the cones. i can't hear a thing from my listening position.
For those who have hum with theyr gainclone (loud or not)Hide this!Advertise here!
For those that like it loud RacerXtreme Multi-Way 25 12th September 2007 04:02 AM
loud hum w/ 1st Gainclone JazzzSpazzz Chip Amps 24 8th December 2004 03:21 PM
GainClone not Loud HouRman9 Chip Amps 5 10th September 2003 03:11 AM
My Gainclone is too Loud PaulHilgeman Chip Amps 5 16th February 2003 01:02 AM
