Old 25th October 2010, 12:04 PM   #11
I prefer the preamp and other sources to be input filtered to approximately 1octave wider at both HF & LF than the Power amp input filters.
Some builders set the HF filter for a pre-amp at >500kHz (RC~0.33us)
and power amp filters anywhere between RC=1.5us upto 0.3us.
regards Andrew T.
Old 28th October 2010, 03:29 PM   #12
Arsimantur's Avatar
Originally Posted by pacificblue View Post
- R1 should go from pin2 to ground, not from output to ground.
right, thx
Ok, I made it, it works and it doesn't. Connected to tda7375 - no sound, only vibrating low tone loudspeaker. When connected to headphones sound is quiet. It should be louder with it not quieter!
I give up, how can I make my speakers with tda7375 connected to mp3 player play as loud as connected to pc?
Old 29th October 2010, 08:05 PM   #13
Arsimantur's Avatar
It was faulty capacitor C3, I put new one and it works now. I also put 100k resistor in place of 1k (R6) to lower HP filter and removed LP filter(C1). I run it from one 9V battery.
Simple 60dB discrete low noise amplifier (lna) ikoflexer Solid State 440 19th November 2010 04:18 PM
Newb needs help eliminating hum/noise in simple mixer schweinhundert Analog Line Level 7 2nd May 2010 01:03 AM
Preamp Noise SState13 Analog Line Level 4 23rd November 2009 03:40 AM
Preamp hiss noise morfeas Tubes / Valves 10 17th June 2005 04:52 AM
Simple and Low noise Pre-regulators for DAC machinow Digital Source 2 10th September 2004 01:04 PM
Page generated in 0.06417 seconds (71.00% PHP - 29.00% MySQL) with 11 queries
