| Chip Amps Amplifiers based on integrated circuits |
I want to have a low pass filter on the input of my gainclone amp. it is used to drive my subwoofer, and i thouht that it would be easier to have a LPF on the input, than to make on for the output. i am aiming for approx 80hz cutoff. im guessing this would be done with a capacitor and resistor?
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#2 |
Its been posted before, search for pllxo, but I think this is one of the sites the thread refers to
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html Thought about this for the car "sub" amp - they're 6" 4R 125watt nominal cheapies & a capacitor from the network point to phone converters in the office (PABX or secondary device selector) is polypropelene 185nF 250v which would give a F of 86Hz on 10k resistor & 172Hz on 5k Cheers Paul |
#3 |
this is for the input to the amp, not the output?
#4 |
Check out this link
http://www.analog.com/Analog_Root/st...er/filter.html It shows you how to make up to an 8th order filter with op amps. Might be overkill for you, but I thought it was interesting. But yes, you can make a simple 2nd order filter just using a RC network. Corner frequency = 1/2*pi*R*C I think the resistor comes first in a low pass filter, but I won't swear to it, I was never very good at analog stuff. Randy |
#5 | |
Account Disabled
#6 |
Hi Matt,
The link I posted is for putting in-front of the amp, it can just about be built into a matchbox size box with inputs for your rca leads & outputs that plug straight into your amp. Component count is 1 cap & 1 resistor so its cheap as hell to try it & since the frequency point changes with the resistance you can even try a 10k resistor in parallel with a 10k & a 50k pot - that would give you a variable resistance from 5k to about 8.5k for experimentation. On my car setup idea that would result in a frequency cutoff of 172 to 100 Hz on a 185nF capacitor. As always I haven't got round to trying this yet. I asked Santa for a few more hours a day for Christmas. Cheers Paul |
#7 | |
Account Disabled
#8 | |
randy |
#9 |
Account Disabled
randy, that's a good suggestion.
Alternatively, you can get the opamp book everyone is talking about from National and it has plenty of examples for active filters. |
#10 |
Hi Millwood,
Yeah I saw that too. I downloaded it already, I plan to print it out later when most people have left work, since it's sooo long. My analog knowledge is pretty weak, so I'm sure I'll learn alot from it. Randy |
| Low pass filter? | happyb | Car Audio | 5 | 11th December 2006 09:47 PM |
| Low pass filter help | ifrythings | Subwoofers | 1 | 24th February 2006 09:45 AM |
| Low Pass filter | ThSpeakerDude88 | Everything Else | 4 | 8th November 2005 02:53 AM |
| low pass filter | crazyant | Car Audio | 3 | 15th September 2005 06:15 PM |
