Old 5th October 2010, 02:50 PM   #1
Default Change of gears. Going to start basic, need suggestions. (NOT a long post this time!)
For now I've decided to go for something simple to start out. I don't care how good or bad chip used will sound in the end, I just want to get my feet wet and have a finished product that WORKS :\
Among the many SMD chips I have, which will be too small for me to work with at this point in time, I have a bunch of through hole chips I'd like to maybe have a go at.
With that said, I now am wondering a couple things. The first Q(s) is a sort of "What is this and will it work?" I've got a few chips that my Google searching and Datasheet site browsing have turned up zilch for, but some have turned up possible hits (different part number prefix which I'm not sure if it changes the part function entirely or not).
As I have a new motherboard with a far superior audio codec than my last one, I've put aside my desire for a headphone amp. I'm now looking to drive 2 to 4 Logitech Z-560 Tang-Band (15W I believe, and I can dig up the Ohms if needed) Sat speakers. Mainly for simple Windows audio.
First is a Sanyo disconn item: STK5446 (I cannot find a datasheet or other info except These two things.)
-On the bottom right corner, in smaller font reads 1D09. On the thermal side is stamped 5446B and under it CC94 (Date code I assume given the age of the unit it came from)
Next: LA6510
-Has 4R9 on the line below. Not sure if that 1A output current is considered good or not... As the datasheet image show, it has a small metal, what I'll call "mono-fin heatsink" stick out the top with a hole. So if it is a decent choice I can probably sink it if that'll help any lol
Finally, which I think might be the best option: BA10324A (Here is also an older scanned original)
-There are a few other listings for datasheets on it, one being very long except it has an added F suffix (although... this one DOES list it in with the A and another), which could mean a whole lot as I've discovered so is pretty much irrelevant I think. It has no discernable manufacturer screened on it (to my untrained eye at least).
Honorable Mention, since I have 4 or 5 of them, and I'll who it verbatim how it reads off the chip...
2903D
---JRC
-.4047G
I've only bee able to track down a datasheet using "JRC2903D" but those results are a mixed bag it seems. It seems like possibly "NJR2903D" is it's new part number as NJR and JRC are one in the same or have merged. I thought I had a datasheet for it, but I can't seem to find it anymore I THINK it was called a "Op Amp Comparator", which I've not exactly dug into what it's function is short of what it's name implies
So yea, essentially wondering which would be the best one to start with. As for powering it, I could REALLY use suggestions. My plan is to spend almost nothing and use all the random parts I've salvage around here (which is amassing to be quite the assortment), with hopefully the only thing I'll need is resistors. Some of them I noticed the voltage requirements being a tad up there, I assume that ones showing -/+15V are essentially 30V components. While I have transformers around that I believe can supply, one that came out of the same component of the STK5446 was showing in the 40V area, but I have zero knowledge on how to wire up a transformer (the PCB it was on broke when I dropped the beast... oops) And this might be a tall order, but from what I can tell some/all of those don't have a simple working circuit diagram, so if anyone would have an idea of how to wire one up for audio (provided they can do that), that would be a HHHHHHUGE help!!
Thanks again for everything!
-Clint
Old 5th October 2010, 03:25 PM   #2
Hi there,
as you've somewhat reduced your desired specification level, you might like to have a look at this Ebay item;
TWO, new 80W rms HI-FI Amplifier ICs type LM12 LM12CLK on eBay (end time 09-Oct-10 19:31:13 BST)
Only two of them, I'm afraid as I might have had a bid for them myself.
Seriously high powered simple Op Amps with 10Amp output capability. Internal protection and no messing about with bootstrapping and all the other external components that most of the "Hi Fi" chips seem to require.
Theoretically, 1 one LM12CLK plus half a dozen external components will give you a 60W amp into 8R.
Sandy
Old 5th October 2010, 04:36 PM   #3
Originally Posted by mnemneth View Post
Hi there,
Sandy
While they are pretty cheap, you'll have to just nab them all
As it only "Ships to:United Kingdom", and I'm in the States :\
Appreciate it though!
Old 5th October 2010, 05:35 PM   #4
Then don't touch this IC.
LA6510
The TDA7560 you already have is easier to build. It only takes one input capacitor per channel and two resistors and two caps for muting and standby and four caps for the power supply. You should try to finish that before starting anything more complicated.
BA10324A
That is an op amp. It will not give sufficient output power to drive any serious speaker load other than headphones.
It seems you are trying to take the second step (building) before the first (understanding).
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 5th October 2010, 06:51 PM   #5
However, if you search Ebay your side of the pond for LM12 you'll find quite a few over there, as well.
Sandy
Old 5th October 2010, 11:36 PM   #6
If you have a power supply and a fair set of resistors and capacitors, why not just request a few samples of some audio IC's? For really simple you could go with something like an LM1875 or LM3875. One channel per IC seems simpler to me than 4 channels per IC. It's a lot easier to solder at least
Tyler
Old 6th October 2010, 06:10 PM   #7
[QUOTE=pacificblue;2323498]Then don't touch this IC.
[/quote
I guess what I implied was: "Does anyone know what this is and/or have the datasheet" :\ It's alright though
I know, but the problem is my breadboard's holes are spread out just a tad too much and I really can only fit in 2 channels. Which is fine, but it got a bit frustrating when I went through all the work of getting it all laid out how it "should be" and then I find that the datasheet I'm looking at is for the non-A. To make matters more confusing, the A datasheet doesn't mention an off-set pin package (horizontal I believe it was calling it), only the other SIP (vertical) package. So I had to take everything out that I just got done laying out, bend a whole bunch of other pins around (snapping one of the "TAP" pins, which I have no clue what is) then try my best to go through the pins, count which one should be what, and then hope I did it all correctly :\
If this 6510 will work though, I'd much rather use it, as its pins all line up perfectly with my breadboard.
Well I originally had planned on a HP build, but my new motherboard has wwway more than enough power now.
I won't argue with you there. I don't pretent to understand what I'm doing, and I mentioned that in my "New Members" welcome area, as well as the other thread about the 7560. I have learned quite a lot (IMO at least) in the last couple weeks, going from little or no knowledge, to... well substantially more but still far short of what would be useful That's why I want to try and build something first, because I'm a hands on person. So if I can manage to get just one done first, no matter how good or bad it sounds, it'll make things easier for me.
Sandy
I know, I had. They're about 20x what I'd want to spend heh And that is just for ONE part!
As I said before, I just want to toss something together to get things rolling. I've already screwed up one circuit (TDA2822M) two or three times, I just don't want to risk killing anything yet that I've paid for or is of good quality.
They may not be an ideal means of power, or recommended for that matter, but I have ways of supplying power. I also have a boat load of capacitors ranging from small to large in capacitance and voltage, and good quality to average quality and even shoddy quality that I wouldn't even consider using in an audio build heh
And I've thought about asking for samples before, but I've never really knew what to put down in the request form. They always ask for a company and I can't imagine they'd send them out if I was to put "personal use" or something, or if I lie and make up a company what would I even put
Old 6th October 2010, 11:16 PM   #8
What kind of power supplies do you have? Single or split (aka dual, +/-), what voltages?
A transformer on the order of 30V - 50V AC would be good if it has a centre-tap (so you have 15V - 25V AC from the centre-tap to each secondary), or if it's dual secondaries, 15V - 25V AC for each secondary.
What impedance are the speakers you want to work with?
The speakers you mentioned above, being 15W, sounds like an LM1875 would be a good starter project. It's capable of about 20W, and only 5 pins.
Tyler
Old 7th October 2010, 03:45 AM   #9
Lots of DC stuff is about it. Save for computer SMPS which has -12v (but only .8A on that rail), it's just +/- stuff. Sadly all I have are rectifiers ICs too, no inverters.
I have transformers, but they are all of the PCB flavor, not that I know how to wire them anyways
The speakers you mentioned above, being 15W, sounds like an LM1875 would be a good starter project. It's capable of about 20W, and only 5 pins.[/QUOTE]
8Ω
I'm starting to get the feeling I should stick to computers and cars
Ironically I decided to see exactly HOW powerful this onboard audio is, and at 89% volume, it is very capable of driving 2 of the above speakers. Though I suspect given it is likely intended on driving passive speakers of a much higher Ω, that prolonged usage will result in the burning out of something so... it was just a test in the end heh
Old 7th October 2010, 04:43 AM   #10
Try something even less stressful for a first project, try a ready-assembled kit. Radioshack or similar consumer electronics stores should have some kind of 5-20W amp kits with circuit board and all components (except transformer and heatsink). There's some REALLY cheap LM3886 and Tripath amp kits from China on eBay but I don't trust those as they're 1/2 the cost they should be for the components included.
Basic CD player Mods - where to start a.wayne Digital Source 16 19th September 2010 05:04 AM
How much do tweeters change over time? Conrad Hoffman Multi-Way 1 20th October 2009 03:05 AM
Long post! Speaker retrofit project... Advice, help, suggestions welcome fazman Multi-Way 19 7th November 2007 10:21 AM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 10:53 PM
Page generated in 0.14631 seconds (86.17% PHP - 13.83% MySQL) with 11 queries
