| Chip Amps Amplifiers based on integrated circuits |
hello, reading the OPA1641 datasheet I don't understand the output stage. Can somebody help me simulating it using LTspice ? See attached .jpg
#2 |
the output is a push pull common emitter stage. If there is a push pull common collector output stage in the voltage amp hidden in the opamp triangle then effectively this becomes a CFP output stage.
regards Andrew T. |
| Help with input stage driver for EL84 output stage | AudioGeek | Tubes / Valves | 2 | 20th March 2010 01:38 AM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| TV Horzontal Output Transistor for output stage..? | ronybc | Solid State | 46 | 10th October 2005 02:26 AM |
| Page generated in 0.07103 seconds (63.52% PHP - 36.48% MySQL) with 11 queries |
