Old 13th October 2010, 07:57 AM   #41
Makk is offline Makk  Finland
I decided to do active preamp..
Pre Tone Control Stereo by IC NE5532 -Audio -Electronic Circuits Diagram-Elecpod
what do you think about this? sure looks easy and NE5532 should be enough good chip. Does this circuit keep signal flat? like ____________, when pots centertapped. I'm going to use rotary switches instead of pots. Volume pot will be 10k.
Old 13th October 2010, 02:38 PM   #42
you need a +-12v supply. You could grab that from your lm3886 rails via some lm317 and lm337 regulators. If you swap the volume pot from 100k down to 10k you might have to change the input cap (then again its 47uf allready).
Old 13th October 2010, 06:42 PM   #43
mjf is offline mjf  Austria
hello.
if you turn up the volume pot fully and the balance pot too (in direction of that channel) ..........it looks to me the input is shorted.so a protection res on the balance pot could be usefull (e.g. 2,2k from balance pot centertap to ground).
greets
Old 13th October 2010, 07:00 PM   #44
OK. I can test that circuit then. But is it "same class" with LM3886?
Second option is using Pedja Rogic's J-fet buffer. I just don't know can I somehow include passive tone stack (baxandall) with that. Should buffer go before or after tone stack and is one buffer per channel enough.
Old 13th October 2010, 07:17 PM   #45
QUOTE=Makk. I can test that circuit then. But is it "same class" with LM3886?
.........this is a standard tone control,used in hundred's of amplifiers........you can change the values a little bit if you like.
and you can increase the powersupply up to +-15volts.
Old 28th October 2010, 10:04 AM   #46
Hey, I made preamp using the schematic mention above. It doesn't work like it should. The problem is that it generates output all the time. Output when volume is 0 is 2,4V and when its full its 2,7V. Bass and Tone controls affect the voltage. Bass full anticlockwise and volume 0 the voltage is 3,3V. Turning also treble to full anticlockwise its 5,3V. If I turn all three knobs fully clockwise voltage is 1,8V. And when Treble and Bass are fully clockwise and volume fully anticlockwise the voltage is 0V. Sound from my test speaker is very BZZZZZZZZ even when there is that 0V from preamp. What could be the reason for these problems? I haven't tested amplifier without preamp, but I think it works. I measured DC offset before preamp assembly and it was ok. Testing sound comes from computer.
Old 28th October 2010, 10:33 AM   #47
Makk,
you say the 3886 tests properly without the pre-amp/tone control circuit.
Then post a new thread to ask how to sort your pre-amp/tone control.
regards Andrew T.
Old 28th October 2010, 06:45 PM   #48
The inverting input is AC-coupled, while the non-inverting input is DC-coupled.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 29th October 2010, 12:23 PM   #49
this is what I refer to as mixed AC & DC coupled.
An AC coupled amplifier has a DC gain of 1. This is usually done by inserting a DC blocking cap in the NFB loop.
The AC coupled amplifier also has a DC blocking cap at the input to prevent source offset passing through the amplifier.
Both DC blocking caps must be in place for AC coupled.
Both DC blocking caps must be omitted for DC coupled amplifier.
regards Andrew T.
Old 29th October 2010, 04:42 PM   #50
Exactly. And since more than 90 % of all sources have an AC-coupled output, there is little choice other than to make fully AC-coupled amplifiers.
LM3886 questions sandyhooker Chip Amps 10 18th May 2009 09:11 PM
LM3886 based amp- questions Atilla Chip Amps 12 6th August 2008 04:55 AM
LM3886 Questions and Suggestions Arc Chip Amps 42 14th March 2007 11:03 PM
LM3886 Amp Questions Adam M. Chip Amps 4 8th February 2004 05:04 PM
Page generated in 0.09154 seconds (80.61% PHP - 19.39% MySQL) with 10 queries
