| Chip Amps Amplifiers based on integrated circuits |
#21 |
That can't be it because there's only 2 of the LM3886's on your board. Is your board stereo? If so, then this is not the schematic for what you've got.
#22 | |
The load resistor for the tube is way too low. If it were me, I'd power it up, measure the voltage drop across it, figure the current, and then replace the resistor with a constant current diode. But, I think this circuit has other problems. |
| Cascode Tube Mic Preamp: 12AX7/12AU7 Schematic | 88man | Tubes / Valves | 11 | 10th December 2009 03:23 PM |
| About an hybrid LM3886 amp using 12AX7 tube | gaetan8888 | Chip Amps | 21 | 3rd November 2009 07:08 AM |
| low gain 12ax7 schematic | bakpaosiomay | Analog Line Level | 19 | 18th August 2009 11:27 AM |
| Please help us with this schematic, parallel LM3886 | CJ900RR | Chip Amps | 7 | 9th May 2008 08:40 AM |
| Please Check this LM3886 Schematic | mymindinside | Chip Amps | 28 | 21st August 2007 09:23 PM |
| Page generated in 0.07035 seconds (69.05% PHP - 30.95% MySQL) with 12 queries |
