| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I have to make a choice between two chip amps I have, to build my first amp. The first is a Sanyo STK4412: 20Wx2 (f=1kHz, 8ohms, THD 1.0%) 10Wx2 (f=30Hz-20kHz, 8ohms, THD 1.0%) 0.3% THD (P=0.1W, 8ohms, f=1kHz) see graph attached. STK4412 datasheet The second is a National LM1876: 20Wx2 (f=1kHz, 8ohms, THD 0.1%+N) 0.08% THD (P=15W, 8ohms, f=20Hz-20kHz) see graph attached LM1876 datasheet I have all the components for the STK including transformer but if i'm going for the LM, i will have to buy new transformer plus components, etc. Would it really be worth the extra spending to get that 0.1% THD of the LM or would the difference be insignificant. Any thoughts much appreciated , thanks
#2 |
I say go for the STK,since you already have all the parts..If you don't like it,build up the LM chip later on.
![]() I actually built an amp with the STK4412 a few years ago,From what I recall,it wasn't too bad. I just used the plain datasheet circuit,with some tweaking it might be pretty good. |
#3 |
I doubt you would have to change transformers and get different parts; the example circuit in the STK is shown as single-supply, but looking at the functional schematic it has just about the full pinout of a dual supply power opamp, so you can build it to a typical LMxxxx gainclone schematic. It's really just a bad datasheet.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
ok, thank you for your replies.
On another note, i noticed the LM1876 claims to output 40W per channel (1%thd, 8 ohms) when V+/- is above ~30V. See the graph below. Is this feasible for a chip originally rated at 20Wx2? Last edited by dmx2020; 15th September 2010 at 02:08 AM. |
#5 |
those excessive distortion graphs (1% & 10%) show that these devices can amplify to those powers without destroying themselves. But that is not an indication of quality. Expect a maximum of ~35W into 8ohms @ 0.1% distortion at the supply voltage maxima shown. If you want that power, then choose a PSU that can supply the required on load voltages. But ensure the PSU voltage offload is below the absolute maximum for the chipamp.
regards Andrew T. |
#6 |
hi andrew,
i had a closer look at the datasheet and it actually gives a power out vs supply voltage graph for 0.1% THD (f=1kHz). For an 8 ohm load it goes up to 30W at around +/-27Volts. But the graph stops after this point. Could this be an indication of an upper limit for supply voltage? Btw, the absolute maximum voltage is at 64V (ie: +/-32V) |
#7 |
you have to work back from that specified maximum operating voltage.
I would start with mains at maximum tolerance find the maximum AC voltage for the +-32Vdc and using the regulation of my chosen transformer and normal mains voltage find the normal AC & DC voltages into and out of the PSU. That let's me specify the AC voltages of the transformer. I would expect 240:20.5Vac 5% regulation for my 240Vac supply. Most transformers are specified for 115/230Vac. That brings down the AC to just 19.8Vac when used on a 240Vac supply. I would choose a 230:18+18Vac transformer with lowish regulation (5 to 8%). This will give me an absolute maximum of +-30Vdc when mains is at 254Vac and regulation is 8%. If I wanted to squeeze a bit more from the amplifier, I might think about (but reject the idea) adding a few turns to make this a 19+19Vac transformer. Now that I have my safe Vac I can use the chosen transformer at my normal voltage (~239 to 245Vac). Subtract about 4Volts for voltage sag on short term full power testing. Looking at the graph I see ~28W for +-26Vdc. Summarising, a 230:18+18Vac 8% regulation transformer powering an 1876 from 240Vac gives ~28W into 8ohms.
regards Andrew T. Last edited by AndrewT; 16th September 2010 at 09:05 AM. |
#8 |
Thanks, that cleared things up a lot.
I take it that it would be similar for the STK which i have already running. I currently have the supply voltage at 42.5Vdc (single rail). The chip has an absolute max rating of 56V (39V recomended). The AC input from the transformer is at 31.5Vac. I assume that there is not much more room for increasing the power output of the chip further by incresing suppy voltage (Allowing for voltage sag, abosulute maximum of transformer,etc). Is it correct. And how did you calculate the absolute maximum of -/+30Vdc for a 230:18+18Vac transformer (what is 254V?) isnt it usually 18Vac x 1.414 - diode rectifier drop Last edited by dmx2020; 16th September 2010 at 09:46 PM. |
#9 |
the 240Vac mains supply system has upper and lower voltage limits (tolerance) of 254Vac and 216Vac.
The open circuit output voltage of a transformer is mains voltage / rated primary voltage * rated secondary voltage * [1+regulation] for a 242Vac supply into a 230:18+18Vac 5% regulation transformer this comes to 242/230*18*(1.05) = 19.89Vac. The peak voltage on the smoothing caps with near zero loading is ~sqrt(2) * Vac - diode Vf (0) = [1.414*19.89]-0.5=27.6Vdc A 5% reg, 230:18+18Vac transformer running on 242Vac, the smoothing caps will have +-27.6Vdc on them. Now do the numbers for your mains' supply tolerance and for the rated voltages of your proposed transformer.
regards Andrew T. |
#10 |
ok my plan is to increase the supply voltage of my STK (currently at 42V)
My transformer has two secondary windings, one (currently used) which is at 33Vac (31.5v when loaded) and another winding at 15Vac. If i combine the two, i can get ~48Vac and when converted to DC (1.414*48-0.5) gives approx 67Vdc. And then using some zener diodes bring the voltage down to approx 50VDC. Does this idea sound practical (i.e.: joining the two windings together and using zener diodes to reduce voltage?) |
| Suitable woof & tweet for CV Full Range chip amp? | lunchmoney | Chip Amps | 3 | 20th March 2011 06:00 PM |
| Chip Amp LM3886 stereo kit - built & ready to go | cdoggy81 | Swap Meet | 8 | 24th February 2009 08:26 PM |
| Mini a's Up in SMOKE :eek: | jleaman | Pass Labs | 43 | 20th October 2005 07:04 PM |
| Who has tried a current boosted op-amp (with a transistor) as a chip-amp buffer? | sardonx | Chip Amps | 18 | 19th March 2005 12:23 PM |
| eek, Think this is in the right place TDA 7294V question | PhoenixFL | Chip Amps | 4 | 17th May 2004 03:16 PM |
| Page generated in 0.10950 seconds (84.06% PHP - 15.94% MySQL) with 11 queries |
