is this really a TO-5 insulator?
Old 6th July 2003, 01:58 AM   #1
travis is offline travis
Send a message via AIM to travis
Default is this really a TO-5 insulator?
the package says it is. LM1875 is TO-5, no? what's going on? i don't see how this is going to isolate the chip from the heatsink. sorry there's nothing in the picture for scale. i had to use the scanner. camera is with sister. the pad about 1 cm across.
donuts
Old 6th July 2003, 02:32 AM   #2
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
ermz I think this is used for the metal can type of transistors...you place the stuff on a PCB or small heatsink (which is rarely needed) and than the transistor OVER it...meaning only the 3 legs protude out from the rubber insulator...then you solder it in place...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 6th July 2003, 02:47 AM   #3
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Yes that is a TO-5 insulator but no it is not the correct size insulator for LM1875. IIRC, TO-5 is a small round metal can package used for some transistors etc.
- Dan
Old 6th July 2003, 03:04 AM   #4
theChris is offline theChris
the lm1875 uses a pentawatt (sp?) case which looks similar to a to220 case, but with 5 staggard leads instead of 3 straight leads.
if only it could be used for good, not evil...
Old 6th July 2003, 03:05 AM   #5
li_gangyi's Avatar
You should try finding a rectangular mica or silicon based insulator...its about the size of the chip you are trying to isolate...slightly bigger in fact...
Old 6th July 2003, 04:39 AM   #6
oops, its 220, not 5. i swear that the 1875 pdf said TO-5 the first time i was looking at it.
donuts
Old 6th July 2003, 05:38 AM   #7
li_gangyi's Avatar
yeah..people make silly mistakes like this sometimes...you can get cheapo insulators if you look into broken or spoilt PC PSUs...they have some...just smear your own thermal grease...dun use artic silver~!
Old 6th July 2003, 06:07 AM   #8
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
if i am right, that is a spacer, to give some clearance for the to5 sitting on the pcb...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 6th July 2003, 08:06 AM   #9
li_gangyi's Avatar
yeah...it's a spacer...sometimes it's used to insulate it from the ground plane in a double sided PCB...
Old 6th July 2003, 10:57 AM   #10
Warp Engineer
On Holiday
AudioFreak's Avatar
I think the datasheet calls the package something like TO-220-5, at any rate, whatever they call it, just bear in mind that they are somewhat larger than a standard TO-220 package so insulators meant for normal TO-220 will be of no use.
- Dan
is this really a TO-5 insulator?Hide this!Advertise here!
Where I can find mica insulator MT-200? viktor1986 Solid State 17 24th August 2008 10:54 PM
Transistor Insulator Sources - US Zero Cool Solid State 21 6th May 2008 02:04 AM
I need a HV insulator for TO247AC FETs... batee Power Supplies 17 2nd February 2007 10:02 PM
TO-247 insulator from a TO-3 JCM Pass Labs 11 13th April 2006 08:58 PM
help on choosing insulator rebojorge Pass Labs 4 4th March 2005 07:26 AM
