| Chip Amps Amplifiers based on integrated circuits |
Is it possible to use a single unit PSU to power 5 individual chip amps this way? I'll like to have 5 individual units so I can power up any which one I wish to. Thanks.
#2 |
Yes, it is possible.
Any solution is a compromise. |
#3 |
Thanks.
#4 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
2A slow blow fuse probably won't last long when feeding a 500VA toroidal - the inrush current will eventually kill it. Suggest you uprate this to a 6.3AT.
If you're looking for the best sound, don't run the shield connection of the RCA inputs directly on to the pcb.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#5 | |
#6 |
Have a look at this picture - its only for stereo but hopefully you'll get the idea and be able to apply it to your 5 channel set up. The key point is there's no direct wire from the RCA ins to the PCB - they go first to the chassis ground and only then on to the PCB from the central star point.
More grounding
#7 |
Hi. There isn't any gnd connection at the amp unit for my 5 channel. I did a pair of monoblocks without the pcb gnd connecting to the chassis gnd and there's no hum. When I connect the pcb gnd to the chassis's gnd, I get a hum.
#8 |
Sounds like something's amiss elsewhere in the system then. The principle of taking the RCA shields straight to the star ground still applies, even if the star ground isn't connected to chassis.
#9 |
Can it be this way?
#10 |
Certainly you could try that - it might work. But you don't show the speaker ground return - is that another separate wire? Don't common the speaker ground with the RCA input ground unless you want an uncontrollable oscillator.
| Chip Amps and Pre Amps | bcmbob | Chip Amps | 17 | 13th August 2010 09:38 AM |
| Chip amps vs class D amps | lanchile | Chip Amps | 46 | 21st April 2010 04:38 AM |
| one channel chip dead???? | joka22 | Chip Amps | 5 | 8th January 2009 09:52 PM |
| SMPS for diy audio amps and multi-channel diy amps (and their power supplies) | tlparker | Solid State | 18 | 31st August 2006 10:39 AM |
| Has anyone compared the Chip amps against Class T amps? | soongsc | Chip Amps | 3 | 24th July 2005 11:50 AM |
| Page generated in 0.09371 seconds (77.03% PHP - 22.97% MySQL) with 11 queries |
